Blown Small Block makes 700 hp at Mesa
Here are some pics of a just finished pewee 383 ci on the dyno cart ready to deliver it's going in a 30 Motion for a friend in Venezuela it's one of two pump gas 700 hp mag distributors for river racing down that way. We are also working on two 677 ci blower motors for a Skater they want to break the speed record on the river with these should make 1400 hp on pump gas. We used the serpentine belt and circ. pump set up for using a closed cooling system.
i already have a 383 w/ a weiand 177 single carb blower that makes 670hp in a 69 camaro on pump gas, i built the engine 6 years ago and it runs 11.2 in a 4000 lb 69 camaro convertible
the camaros are fun, where are you in miami?? i run it at moroso once in a while, i just put a tremec 600 in it, so now w/ the overdrive the car is much more driveable, i did also install airide suspension and have had a lot of problems w/ it
