Oil Thermostat, where to buy and which one?
I am replacing my oil cooler after spinning a rod bearing. I will need to be replacing the T-stat as well, lots of places for metal to hide in there. I was using the Permacool oil T-stat.
http://www.jegs.com/webapp/wcs/store...tegoryId=18301
This unit bypasses 10 percent of the oil regardless of temp. I suspect that the bypass rate may be even higher due to them temp differentials.
What other oil T-stats are being used? Not looking for a high dollar part, just one to do the job. Will be mating it the Eddie Marine 3x22 combo cooler.
http://www.eddiemarine.com/cart/deta...&CategoryID=60
t500hps
07-17-2012 09:23 AM
