3M 4200 or 5200 to mount swim platform >
Old 05-22-2006 | 09:05 PM
G Man's Avatar
Default 3M 4200 or 5200 to mount swim platform
what should I use to mount an aluminum swim platform. I will through bolt it but what adheasive / sealent shoud I use 3m 4200 9r 5200?
G Man is offline
Old 05-22-2006 | 09:16 PM
GOODT's Avatar
Default Re: 3M 4200 or 5200 to mount swim platform
5200 only time you will have to worry about it will be if you want to remove it then it will take a heat gun
GOODT is offline
Old 05-22-2006 | 09:45 PM
MOP
4200 or 5200 will work as will silicone does well the important thing is good fasteners and correct sized holes so the fasteners don't work under laod, the 5200 can be gotten loose with DeBond a bit messy though.
Phil
MOP is offline
Old 05-22-2006 | 09:57 PM
Elite Marine's Avatar
I recommend 4200. It is safe for under waterline applications and will not remove th gel, fiberglass, wood, resin etc..if you need to pull the platform ever.
Elite Marine is offline
Old 05-22-2006 | 11:13 PM
I would use the 4200, actually I did when I mounted my swim platform. same sealing as 5200, but about 50% of the adhesive properties.
Griff is offline
black Peal
Scarab
6
02-20-2012 12:54 AM
Prater
Grand Lake/LOTO/E-Dock
6
08-15-2008 03:24 PM
psmith
Chris Craft
3
07-31-2006 06:15 PM
G Man
Detailing, Painting, & Fiberglass
5
05-25-2006 12:18 PM
Outlawcowgirl
Baja
16
04-23-2004 07:52 AM
