Engine Pre-lubers >
Engine Pre-lubers
Engine Pre-lubers
Old 05-23-2006 | 11:43 AM
itilldo's Avatar
Default Engine Pre-lubers
Looking for info pertaining to engine pre-lubers. I have a single 525 and I would like to know if anyone here as installed one on their motor/s. If so , are you happy with the brand that you have and how was the install? Any info would be very helpful.
Thanks,
Eugene
"itilldo"
itilldo is offline
Old 05-25-2006 | 07:52 PM
monstaaa's Avatar
Default Re: Engine Pre-lubers
these work great and are not bad to install.
monstaaa is offline
Old 05-25-2006 | 09:02 PM
Frequency's Avatar
I installed the Eickert kit on my motors a couple years ago. It's basically a check valve and Moroso fuel pump with high pressure hose and fittings. The suction side plumbs into the oil pan drain valve. You will need a momentary switch to energize the pump. The install takes a little work. I put a quick disconnect fitting in mine. I put another fitting on a ten foot long piece of hose and use it to pump the oil out of the pan for oil changes. Works great.
Frequency is offline
Old 05-26-2006 | 06:02 AM
Pwrbt33's Avatar
I believe Monstaaa and I install the same brand, I use Master Lube. There nice units and easy to use and maintaine. I had custom brackets made because I dont like there way of mounting, but other than that a nice piece.
John S.
Attached Thumbnails Engine Pre-lubers-maximus-imco-lwr-022.jpg   Engine Pre-lubers-maximus-imco-lwr-024.jpg   Engine Pre-lubers-maximus-imco-lwr-014.jpg
Pwrbt33 is offline
Old 05-26-2006 | 12:08 PM
Here is the Keith Eickert system installed on a rear engine mount. Clean and out out sight...
BenPerfected is offline
Old 05-26-2006 | 12:09 PM
missed attachment
deboatmon
39
06-05-2009 11:55 PM
powercat
8
04-11-2008 08:05 AM
deboatmon
38
01-09-2007 07:24 AM
InXS
11
03-06-2006 03:57 PM
outlawinil
6
03-01-2003 08:42 PM
