Saw this in the classifieds...????? >
Old 05-25-2006 | 08:10 AM
bouyhunter's Avatar
Default Saw this in the classifieds...?????
Glancing through the classifieds I saw this http://www.offshoreonly.com/esvon/files/10410_1.jpg
Not bashing, but how do you get the boat off the trailer? Hoist? does it float over the rear "bumper"?
And what's the deal with the single exhaust for each motor?
bouyhunter is offline
Old 05-25-2006 | 08:21 AM
Pantera1's Avatar
Default Re: Saw this in the classifieds...?????
The drive guard must swing away somehow ??
Those exhaust tips dont look to be sealed around the transom too well, good way to rot the transom ..
Pantera1 is offline
Old 05-25-2006 | 08:23 AM
bouyhunter's Avatar
Also the way the exhaust is run - http://www.offshoreonly.com/esvon/files/10410_7.jpg
I'm kinda scratchin' my head on this one...
Old 05-25-2006 | 08:27 AM
Pantera1's Avatar
Why ? 2 into 1 .. quieter ? Your probably giving up HP that way anyways
Pantera1 is offline
Old 05-25-2006 | 08:40 AM
Wobble's Avatar
SORE MEMBER
2 into one wont necessarily lose hp, if it's big enough, there are benefits to be had hp wise just as there is with a balance pipe or crossover on any hi perf motor.
Probably not the case here
Wobble is offline
Old 05-25-2006 | 09:01 AM
Sean H's Avatar
A to Z
two into one can make as much or more power if done right....
Attached Thumbnails Saw this in the classifieds...?????-2005_1201mtipics0053.jpg   Saw this in the classifieds...?????-2005_1201mtipics0034.jpg   Saw this in the classifieds...?????-2005_1201mtipics0072.jpg
Sean H is offline
Old 05-25-2006 | 09:21 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
wow that is one kick ass trailer nice access around stern would like to see how the center section lifts out and and to my trailer
klaw is offline
Old 05-25-2006 | 09:52 AM
Wally's Avatar
Were doomed!
I bet the center diamond plate comes off and you need to lift the drive up a bit to get off the trailer....would suck if its a shallow ramp though.
I've seen that 2-1 exhaust a few times before.....one that comes to mind id the Wellcraft Nova III's, they had it that way and had a cool stainless side dump.
-Wally
Wally is offline
Old 05-25-2006 | 09:56 AM
Smitty's Avatar
Alot of Sea-Rays do the 2 into 1 thing.
Smitty is offline
Old 05-25-2006 | 10:38 AM
TEAMBAJA's Avatar
Im guessing there are rubber gaskets on those tips? No way there could be that much gap!
If the drives were trimmed up, wouldnt it float right over top?
TEAMBAJA is offline
