Who has High output alternators? >
Old 05-27-2006 | 05:44 PM
LubeJobs42's Avatar
Default Who has High output alternators?
I'm putting a big stereo system in the new boat. I've been trying to find high output "marine" alternators with no luck. Anyone know who has them in 160 to 200+ amp??
I found them in up to 250 amp for auto applications. Can I use these or do they need to be espically for marine?
LubeJobs42 is offline
Old 05-27-2006 | 06:11 PM
ChrisK's Avatar
Moderator
Default Re: Who has High output alternators?
We had a local aleternator shop rebuild the stock ones to 250 amps each when we had issues power wise on the scarab. Same body, better guts.
ChrisK is offline
Old 05-27-2006 | 07:20 PM
packinair's Avatar
No Comment
From: This post copyright, Packinair Inc. All rights reserved.
there are ones called mean grean that are supposed to be good
packinair is offline
Old 05-27-2006 | 08:05 PM
bigd1's Avatar
I think the only difference for marine is the screens on the vents. I got mine here:
http://www.4alterstart.com/pages/sto...art.com/marine
bigd1 is offline
Old 05-27-2006 | 10:55 PM
A good secret is to use a marine deisel alternator...they make more beans...and start charging at a lower rpm....great for idle zones
flash32118 is offline
Old 05-28-2006 | 08:31 AM
gmhdfan's Avatar
Chevy-Harley fan
I think I have a couple of brand new ones that came off a Caterpillar motor if you are interested.
Pete
gmhdfan is offline
Old 05-28-2006 | 08:41 AM
I got my 130 amp one from dbelectrical
they are large case, 1 wire and were a snap to install
ckentling is offline
Old 05-28-2006 | 08:45 PM
LubeJobs42's Avatar
Hi Pete, do you know if they are over 130 amp. If they are what do you want for them? Thank you
Old 05-29-2006 | 01:16 PM
FeverFan's Avatar
Joe has Balmar alternators on his Gun, the seem to work good.
http://www.balmar.net/
FeverFan is offline
Old 05-30-2006 | 05:17 AM
Iggy's Avatar
I bought my 100 amp alternator from www.dbelectrical.com too.
One word of caution, a larger output usually means a larger housing. I had to use a shorter than normal drive belt to get mine to work. If the belt stretches more than an inch, I'll need a new belt.
Iggy is offline
