1995 ford 7.3 powerstroke
Old 05-27-2006 | 08:44 PM
Default 1995 ford 7.3 powerstroke
I am looking at a 1995 ford with the 7.3 powerstroke. it has 190K miles on it with new injectors, brakes, and rotors. Did this year diesel have any issues?
sonicator is offline
Old 05-28-2006 | 05:44 AM
Default Re: 1995 ford 7.3 powerstroke
None that I'm aware of. My 96 powerstroke has 275K on it. The two things that seem to go on them are the CPS on the front of the engine and the glow plug relay. You can go to thedieselstop.com for more info.
88Fountain is offline
Old 05-28-2006 | 09:46 AM
DirtyMoney's Avatar
Probably one of the most trouble free years ever. I had a couple with over 300k on them.
DirtyMoney is offline
Old 05-28-2006 | 10:33 AM
lucky strike's Avatar
We are taking in on trade a 1992 Ford f-350 7.3 Diesel Dually Crew cab with 106k miles Needs a paint job anyone have any interest in it. ?
lucky strike is offline
Old 05-28-2006 | 11:15 AM
nocigarette's Avatar
Got One Now With 336,000 On It, Glow Plug Relays And Thats It....
Pulls Better Than My New Cummings
nocigarette is offline
Old 05-28-2006 | 11:23 AM
hillbilly24's Avatar
There'sno F'ing G in Cummins
hillbilly24 is offline
Old 05-28-2006 | 11:28 AM
I have 2 of them, one with 330k that has had 3 tranny's, 3 CPS's, 2 glow plug relays, 1 ring&pinion, 1 water pump, 1 gauge cluster, 1 anitlock controller, and 1 transfer pump. The other only has about 250k with no problems. They both are attached to a 15k lb ++ trailer everyday. They pull great on the flat & level, (which is what I use them for), but do not have nearly the pulling power of my '99 Dodge Cummins.
On your way home from buying it, stop by the International Dealer and buy a CPS and put it in the glove box. The ~$120 part will just quit working with little warning and you will be stuck. It only takes about 2 minutes to change and can easily be done on the side of the freeway
yeehaw is offline
Old 05-29-2006 | 09:34 PM
Thanks for the info. I think I am going to look for something a little newer than the 95.
Old 05-29-2006 | 10:53 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
2000 - 2003 with the 7.3L PSD are prime. I just picked up a 2000 PSD a few months ago with 58K miles. LOVE IT.
1995 -1999 are virtually the same with minor changes.
1999.5 through 2003 are BULLETPROOF 7.3L PSDs.
Sydwayz is offline
Old 05-30-2006 | 06:57 AM
Registered User
Judging from how often I see it mis-spelled, I'm beginning to think it's an error on Cummins' part.
Chris Sunkin is offline
NKissau
34
05-03-2008 09:15 AM
tomtbone1993
4
04-14-2007 09:23 AM
Crazyhorse
12-04-2004 10:59 AM
Wally
01-15-2004 08:54 AM
Audiofn
07-22-2002 09:37 AM
