cigarette cafe in need of prop help >
Old 05-28-2006 | 07:57 PM
4195's Avatar
Can You Hear Me Now??
Default cigarette cafe in need of prop help
I have recently repowered my boat with new 500 HP the boat will not go over 4950 rpm I am using a set of Bravo 25p 3 blades. Believe or not I am getting 74 out of it. I need to know what would be best route 3 or 4 blades and wwhat pitch? The boat has bravos 1:5 ratio. Also what can I expect to gain in mph once a gain 250 rpms?
4195 is offline
Old 05-29-2006 | 07:54 PM
The Menace's Avatar
Default Re: cigarette cafe in need of prop help
You didn't mention your red line or the rev limiter setting. If your red line is 52-5300 and you have full tanks and a couple passengers you may be in good. shape. As you burn off fuel you will pick up some R's.
If you are to be at 5600 to 6000 you have too much prop at her right now.
The Menace is offline
Old 05-30-2006 | 06:33 AM
4195's Avatar
I had a half tank of gas and only 2 people on the boat. Red line should be 5200
4195 is offline
Old 05-30-2006 | 10:38 AM
4195's Avatar
Julie or Brett where are you I need some help
4195 is offline
Smokinlegend
01-31-2026 09:16 AM
kevint
0
05-24-2008 05:27 PM
pm203
05-11-2007 11:21 AM
Steve Snider
Prop Talk
4
10-31-2006 11:48 AM
miamioffshore
02-07-2006 09:33 AM
