Go Back  Offshoreonly.com > Owners Forum > Nordic
2001 nordic 35 flame >
Old 05-29-2006 | 07:05 PM
Default 2001 nordic 35 flame
just bought this boat. what is the best setting for the drives at cruising speed and trim tabs. Also. the boat has three gas tanks with a switch on the dash for LH/RH and gas tank switches in the engines compartment and three exterior gas fill nozzles. Is the large center tank considered RH or LH. Nice boat, lastly had a 32 fountain-the nordic has more bounce than the fountain unless I'm trimming it incorrectly(boat has 500 EFI's). thanks!
tomswift is offline
Old 05-30-2006 | 08:55 AM
TSPM's Avatar
Default Re: 2001 nordic 35 flame
They set them up that one position is the side tanks and the other position is the belly tank. Which is which varies depending on who rigged the boat at the factory.....just run on one postion for a while until the fuel level drops....then you will know what postion is for what tank system. Once on plane very little tab if any and drives slightlly out. Of course water conditions and turning you will need to adjust slightly. The 35 is a very neutral boat with not a lot of bounce ....so keep getting seat time. Also they fly very level and re-enter perfectly every time.
TSPM is offline
sandcraft
Nordic
20
04-16-2011 06:19 PM
peterson
Nordic
16
05-13-2006 05:10 PM
Dean Ferry
10-29-2004 08:23 PM
JKK
01-07-2004 11:24 PM
