waterin bilge >
waterin bilge
waterin bilge
Old 05-30-2006 | 09:15 AM
Angry waterin bilge
fountain 35ex water in bilge.i checked all the hoses when running no water but water in bilge checked the bellows dry.could the water comr=e thru the bilge pump fittings they are very close to the water line?
sonic28 is offline
Old 05-30-2006 | 09:34 AM
Ted G's Avatar
Default Re: waterin bilge
Could be backing up through the air vents beside the swim platform.
www.cbpba.com
Ted G is offline
Old 05-30-2006 | 10:22 AM
sleeper_dave's Avatar
My circulating water pump was bad last year. At idle, no symptoms, at WOT, water would come out of the weep hole on the bottom, like when a car water pump goes out. Only found the problem when i was checking the timing on the motor. No overheating or other symptoms.
That could be your culprit.
sleeper_dave is offline
Old 05-30-2006 | 12:02 PM
carrboy's Avatar
I just had to change the seal on the top of the gimbal ring where the pin connects the ring to the housing...I hear it's very common.
carrboy is offline
Old 05-30-2006 | 01:11 PM
Angry Re: waterin bilge
nope to all above still waterin the boat is new and has 2 hours on it.
sonic28 is offline
Old 05-30-2006 | 01:31 PM
Wally's Avatar
Were doomed!
Take some strawberry jello and dust the bilge area when its dry down there.....go for a ride and see if it will show you where the general area the leak is coming from. Theres soo many places water can come from....
Ive seen the raw water pumps with hairline cracks in them that dont show up till the boats on plane then the combination of the engine RPM and water PSI from the outside lets water seep in.....or on my old scarab the bottom water pickup wasnt sealed properly and it leaked into the hull.....but not past the fitting on the inside of the boat!!...NO It found its way THROUGH the hull and was leaking by a support stringer that had a small crack in the corner!!! Drove me crazy
-Wally
Wally is offline
Old 05-30-2006 | 06:07 PM
GOODT's Avatar
Wally, thats a great Idea never tought about it.......
like dad use to say " Any day you dont learn something is a day wasted "
GOODT is offline
TopSpin80
Technical Issues
0
04-24-2008 06:32 PM
bluellama
09-01-2006 04:15 PM
impulsive one
04-23-2006 06:58 PM
Prater
04-21-2006 05:39 PM
Mikey Likes It
Detailing, Painting, & Fiberglass
1
03-28-2006 06:39 AM
