Transom Repair ???
Old 06-01-2006 | 03:57 AM
cig1988's Avatar
Default Transom Repair ???
Never done this before & have some ideas. I have an Kona jet with a BBC that had the old exhaust logs thru the transom. Going with Stainless Marine with risers over the transom. I think the holes are around 2 1/2". Any suggestions ?
cig1988 is offline
Old 06-01-2006 | 05:24 PM
offthefront's Avatar
Default Re: Transom Repair ???
wood or foam Plug ......fiberglass ..cloth fiberglass......Gelcoat ...
sounds ez .....
offthefront is offline
Old 06-02-2006 | 03:16 AM
cig1988's Avatar
Thats what I was thinking. I have a nice piece of micro-lam that will work
cig1988 is offline
Old 06-02-2006 | 07:38 AM
Audiofn's Avatar
Charter Member #232
You have to grind a bevel in the glass on the side of the drive opening. This way the glass has something to grap onto. I can not remember what the cut back is per inch of glass thickness but if I was to guess you will be grinding a slope away from the drive about 3" at leaste. Depends on how handy you are if you want to tackle this or not. It is what I would call a large job.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-02-2006 | 09:12 AM
David's Avatar
There are also fancy plugs available to cover the holes when switching to OT exhaust.
http://www.cpperformance.com/detail.aspx?ID=392
David is offline
Old 06-02-2006 | 11:51 AM
cig1988's Avatar
Jon
I hear ya, a 2" repair will probably be spead/feathered to about a 8" area. Should'nt be a big deal. The only PIA will be the paint which is a metal flake from the 70's. I did some hull repairs a few years back. Base coat...clear w/the metal flake..and ALOT of clear on top. Not to mention the wet sanding.
cig1988 is offline
Old 06-02-2006 | 11:52 AM
cig1988's Avatar
Thought about that at first but decided to make it right. Thanks for the input.
Stan
cig1988 is offline
Double R Performance
Nor-Tech
1
08-02-2006 11:34 AM
Mikey Likes It
Detailing, Painting, & Fiberglass
10
06-20-2006 08:36 AM
Mikey Likes It
06-06-2006 01:35 PM
nordic95
12
01-10-2006 10:49 PM
