Paging Doc Hoilday >
Paging Doc Hoilday
Paging Doc Hoilday
Old 06-06-2006 | 09:14 AM
Question Paging Doc Hoilday
Doc,
Your the resident expert on 36 Outlaws. A couple of questions:
1. The midship bilge pump. How does it work? Off the bilge switch on the dash or is it automatic? I don't see a float. Is it in the pump? I had some water on the cabin floor coming out of the front scupper, I checked the bilge and it was full. The pump should have come,on, but it didn't, even when I hit the switch on the dash.
2. A while back you said that you changed the cabin door tracks and supports to stop the door rattle. Could you give me a parts list and maybe post some pics if you have them. I tried to adjust it, but it still rattles. This is something that will drive me nuts if I don't fix it soon.
Thank,
Bret
BRET is offline
Old 06-06-2006 | 12:34 PM
Dock Holiday's Avatar
Charter Member #34
Default Re: Paging Doc Hoilday
Originally Posted by BRET
Doc,
Thank,
Bret
The bildge pump in the cuddy is automatic. There is not a switch for it. There is a float built inside the bottom of the pump. If it did not come on then you probably have a bad pump. I had to replace mine this season.
As for the door system, I have replaced mine with a Linear rail system like they are using on the new Cigarettes. I actually did it before they did!
However the only one that I can find that fits without any major modifications is steel and I have already had to replace mine once due to corrosion.
I will try to take some pictures tonight and post them along with the details. It works great and the door does "NOT" rattle, but it is expensive. The two rails and four block bearings cost me as a distributor right at $348.00.
Dock Holiday is offline
Old 06-06-2006 | 12:44 PM
Charter Member #34
This is a link to HiWin.
They are the cheapest I have found, cheaper then IKO and THK.
http://www.hiwin.com/lg/hg.html
These are the part numbers I used.
4pcs. HGH15CAZOH Linear Block Bearings
1pc. HGR15R1130H Linear Rail (short rail for top)
1pc. HGR15R1187H Linear Rail (long rail for bottom)
Old 06-06-2006 | 01:14 PM
Thanks Dock,
The door is driving me crazy.
BRET is offline
Old 06-06-2006 | 01:29 PM
Charter Member #34
Thanks Dock,
Believe me, I fully understand.
I even ordered new hardware from the company that built the door, SparTech Marine, thinking that mine had just worn out, but the new stuff was no better and it was $50.00 for 7 little plastic pieces!
http://www.spartechmarine.com
Old 06-12-2006 | 10:49 AM
Dock:
Were you the one that posted contct info on ordering Baja parts? I think a lady out of FL if I'm not mistaken. If so, could you repost or PM me?
Thanks.
imartin is offline
Old 06-13-2006 | 08:22 AM
Charter Member #34
Originally Posted by imartin
Dock:
Thanks.
It's not Baja parts, but Mercruiser parts.
If you need anything for your Mercury engine, outdrives, trim pumps, etc. then she is the one to call.
Sarah Robertson
Dell Marine
email: [email protected]
Phone: 904-730-9968
Tell her "Dock Holiday" sent you.
Old 06-13-2006 | 10:16 AM
Sarah Robertson
Dell Marine
Phone: 904-730-9968
Thanks Dock!
imartin is offline
Old 06-16-2006 | 09:39 AM
Bret, Are you up and running again with your door mods and your leaking power steering ??
otis311 is offline
Old 06-16-2006 | 10:08 AM
Hey Robbie,
Nope; they haven't shipped me the parts yet. They said Latham had to mill a new block. Yea, right.
Anyhow, I'll be pontooning it this weekend.
Going to Houston? Picking up something in a barn perhaps?
Pm me
BRET is offline
