bravo drive oil keeps coming out of oil tank on engine on baja 24 >
Old 06-07-2006 | 08:14 PM
jeff32's Avatar
Default bravo drive oil keeps coming out of oil tank on engine on baja 24
drive oil keeps coming out of oil reservoir by cap when rpm goes over 3000, on a 94 baja outlaw I sold. Got the drive tested today and holds 12 pounds all day long. no water in oil. Merc dealer says 2 options: too much vibration on engine should relocate tank, or change the cap. There is a small vent hole on it, but I can't see why it would make suck a mess in such a small hole... What do you think is my solution or problem ?
jeff32 is offline
Old 06-07-2006 | 08:37 PM
johnnyboatman's Avatar
Default Re: bravo drive oil keeps coming out of oil tank on engine on baja 24
prob building heat, how full is the resorvoir. dont over fill it.
johnnyboatman is offline
Old 06-07-2006 | 08:48 PM
JS232's Avatar
Sometimes, changing the reservoir cap may fix the problem. It did happen to GLH on His Cafe Racer. We swaped the caps and the problem switched to the other reservoir
Also, You should NOT keep the oil at the FULL level mark in the bottle. I keep mine just over ADD mark. The level will fluctuate while driving the boat and it's normal.
Is the oil foamy? colored? Smelly?
Also, a damaged and overheating drive may cause a constant oil spill from the reservoir...
JS232 is offline
Old 06-07-2006 | 08:55 PM
ratman's Avatar
make sure you didnt blow a seal and fill the drive with water which can float the oil out via the res.
ratman is offline
GOODT's Avatar
from exp ( 25 yrs building drives) its a sign that its over heating, most of the time from a bad brearing, get it checked out by someone that knows what they are doing.....
the lube gets hot expands blow out where the weakest point is
GOODT is offline
Old 06-07-2006 | 09:11 PM
candyman35's Avatar
[QUOTE=JS232]Sometimes, changing the reservoir cap may fix the problem. It did happen to GLH on His Cafe Racer. We swaped the caps and the problem switched to the other reservoir
QUOTE]
Same thing happened when I switched to new drives a few years ago. It ended up being a bad cap. The Bravo drive runs under pressure. If the cap is not tight or the orange rubber flap in the cap is damaged or missing it will foam all over the place. Hopefully it is that easy.
Dan
candyman35 is offline
JS232's Avatar
Should'nt the oil show some overheating signs then like odors or discoloration?
JS232 is offline
Old 06-07-2006 | 10:29 PM
Check That The Black Gasket Or O Ring Is Still In The Cap.
chad1 is offline
Old 06-07-2006 | 11:06 PM
ChrisK's Avatar
Moderator
Thats why I put a turbosonic cap on my resivour. I would get fluid all over the place when running and hitting waves... swapped caps and no more issue.
ChrisK is offline
Old 06-07-2006 | 11:33 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Do you have a drive shower?? If you dont I would put one on. I can get you one if you need it.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
