Idle RPMs on fresh 5.7?
So I've just gotten a fresh reman 5.7 installed on my boat. It seems that the idle is set very high (1100 rpms) and it may be what's causing some shifting issues. It's REALLY harsh when shifting into fwd or reverse, so much so that it just can't be right. Shifting back to neutral isn't exactly right either... the shifter will "click" into neutral but it will actually stay in gear until the throttle is jiggled a little, then it will kick into neutral.
What should the idle rpms be? or does this not sound like the cause of my problems?
I should also note that it's an Alpha drive.
Once in gear, the idle does drop a little, but only to about 1000 rpms. I'm not sure how to make these adjustments myself, so I'll probably have to take it back to the place that did the engine swap.
Oh well, I just won't get to take a drive this afternoon
Phil
Originally Posted by MOP
"If it is a carb engine" look by where the cable attaches to the carb, down by the carb base right by the arm you will see a screw facing forward turn it slowly to the left. When you get it to about 700 put it in gear and it will drop a little more try for 600 in gear that should take care of it.
Phil
Phil
You can set it to 700 on the hose you may need to touch it up in gear when you launch it, it needs to be under load for proper adjustment.
Phil
P.S. Do it and go play!
Phil
1100 RPM is way to high. 650 -/+
