drive fluid dripping from water pickup.... >
Old 06-12-2006 | 07:09 AM
tssteph's Avatar
Default drive fluid dripping from water pickup....
After sitting last week I noticed a very small puddle of drive oil under one drive. It is coming from the water pickup holes on the side of the drive. It has not lost much fluid at all, may 1/4 in in the bottle. In the water it did not leak the week before. The drived were just off for a repaint this spring and the boat has only been in the water a couple times. I am assuming I have a bad seal but which one? Can anyone point me in the right direction? It is a 1998 Bravo 1 drive.
tssteph is offline
Old 06-12-2006 | 08:28 AM
RedDog382's Avatar
Default Re: drive fluid dripping from water pickup....
Possibly a O-ring between the two drive sections. Had a guy here with lube dripping from the speedo pick-up, resolved after replacing the o-rings.
How are the 27 mirage props working out for you?
RedDog382 is offline
Old 06-12-2006 | 08:37 AM
tssteph's Avatar
From what I remember there are seals between the upp and lowers, is there any other seal that could be the cause?
Sold the 27's, running 28's.
tssteph is offline
Old 06-12-2006 | 09:28 AM
GOODT's Avatar
most of the time when drive oil is dripping out the water pick up it is the o ring between the upper and lower
GOODT is offline
Old 06-13-2006 | 10:11 AM
Mr Gadgets's Avatar
Charter Member #601
There are two orings and a seal that is called a Quad seal. I would replace all three, and make sure the surfaces they mate with are clean, no nicks or bumps, etc..
Hope this helps..
Dick
Mr Gadgets is offline
Old 06-13-2006 | 10:16 AM
tssteph's Avatar
The one front O-ring is for the speed-o pickup right? The two back a little further are for water and oil right? I have a nose cone so the speed-o pickup should not be an issue.
tssteph is offline
Old 06-14-2006 | 08:15 AM
Mr Gadgets's Avatar
Charter Member #601
The fat one is for the speedo, then there is a large one that isolates the water pickup and in that one is the quad seal, isolating the oil passage, then there is the oring around the vertical shaft.. that is an oil cavity
Old 06-14-2006 | 09:47 PM
I used the Merc perfect seal stuff on those...is that OK?
Back4More is offline
Old 06-15-2006 | 05:49 AM
GOODT's Avatar
I like to use 3m super weather strip adhesive ( gorilla snot )
GOODT is offline
Old 06-15-2006 | 06:23 AM
Mr Gadgets's Avatar
Charter Member #601
I use the Merc stuff, but dont remember what it is called.. Gray and white can I think, under all the overspill...
Deltarat
0
08-28-2008 10:05 AM
LZH
Drives and Lower Units
0
02-25-2008 08:18 PM
dualprop
09-11-2006 02:34 PM
deboatmon
1
05-11-2003 08:18 AM
Waterfoul
4
04-15-2003 04:22 PM
