No Start, Slave solenoid? >
Old 06-12-2006 | 08:40 AM
Jerry B
Default No Start, Slave solenoid?
1993 502 EFI. No click at all from the starter several times I turned the ignition switch.The engine hatch was closed so I couldnt hear if the slave solenoid was trying to work. After several attempts the engine started. No problem the rest of the day. I had to replace one of the trim tab solenoids week before last because the up position would not work. Question is, Where is the slave solenoid exactly and is it the same part as the trim and tab solenoids. I beleive this is the problem.
Thanks for the help.
Jerry.
Jerry B is offline
Old 06-12-2006 | 06:48 PM
MOP
Default Re: No Start, Slave solenoid?
The slave is mounted on the same bracket as the circuit breaker, front of the port manifold.
Phil
MOP is offline
Old 06-14-2006 | 11:05 AM
Jerry B
Thanks. I will find it . I ordered 2 solenoids so I can keep an extra on hand.
Jerry.
Jerry B is offline
Old 06-14-2006 | 11:53 AM
Are they not usually on the starboard side?
wrenchman is offline
Old 06-14-2006 | 12:54 PM
Mine just went. Sometimes would start, sometimes not. Then not at all. Somehow it got cracked and moisture got in. Was supposed to be new last yr.
Pure Energy is offline
Old 06-14-2006 | 08:31 PM
MOP
I have been off the wrenchs as a job a few years now but believe they are all on the Stbd side on all I/O setups an all in one setup, main harness, push button breaker and the assist solenoid. Most were bolted to the front of the head.
Phil
MOP is offline
Aero654
11
09-08-2021 06:58 PM
packinair
Swap Shop
10
07-16-2008 09:34 AM
jdub
6
04-13-2007 06:40 AM
seahawk
12
04-29-2004 02:21 AM
