can you run one drive in reverse full time? >
Old 06-13-2006 | 12:04 AM
flatout's Avatar
Default can you run one drive in reverse full time?
I have two regular rotation drives. I heard a little roomer that a guy ran one in reverse and esentially made himself a counter rotating drive. Is this possible? or would it wreck something?
flatout is offline
Old 06-13-2006 | 02:08 AM
ratman's Avatar
Default Re: can you run one drive in reverse full time?
i dont think its that right way to do it, sell your and get the correct rotation, or can the gears be swapped in your drive to make it rotate the other direction?
ratman is offline
Old 06-13-2006 | 05:34 AM
Pwrbt33's Avatar
If its an Alpha or a trs its not cool to run those in reverse as a full time fwd. The way the gears are cut in an alpha you will essentually be pushing the gears apart rather than pulling them together. The trs is different because you can run the transmission in reverse under a heavy load like that, it will burn up clutches after a very short time.
John S.
Pwrbt33 is offline
Old 06-13-2006 | 08:47 AM
flatout's Avatar
thanks guys, I think I will just go with the counter rotating lower. I found one on ebay for $1500.00. Just wanted to see if it would hurt the drive. What you are sayin makes sense so ickna on the backwards.
flatout is offline
Old 06-13-2006 | 09:36 AM
BajaRunner's Avatar
What kind of outdrive?
BajaRunner is offline
Old 06-13-2006 | 09:39 AM
mopower's Avatar
Toxic FORMULA
Bravos are essentially run in reverse for left hand rotation. Early Volvos are that way too , don't know about later ones
mopower is offline
Old 06-13-2006 | 12:16 PM
flatout's Avatar
alpha's
flatout is offline
Old 06-13-2006 | 12:36 PM
BajaRunner's Avatar
Originally Posted by flatout
alpha's
you need a counter rotating drive.
Old 06-13-2006 | 12:48 PM
Or at least the c/r lower......thats the difference on a alpha.
JaayTeee is offline
dj_merk_e
14
02-18-2008 08:39 PM
Jassman
4
01-25-2005 10:40 PM
splashandburn
4
03-03-2004 01:07 PM
Mad Hatter
15
07-07-2003 02:30 PM
timucin
5
06-30-2003 02:41 PM
