Cleaning up transom
Old 06-14-2006 | 11:32 AM
Prater's Avatar
Default Cleaning up transom
I have started to clean up the transom on the 357 I just purchased. What is the best way to get silicon off the gel? I have a lot of cleaning ahead...Any suggestions
Here is what I am starting with
After the removal of the swim platform and lots of little screws
Prater is offline
Old 06-14-2006 | 01:20 PM
cuda's Avatar
Default Re: Cleaning up transom
Razor scraper, then try laquer thinner. Silicone is a b1tch.
cuda is offline
Old 06-14-2006 | 03:01 PM
offshoredrillin's Avatar
3M wheel for removing decals works well and wont hurt gel...
offshoredrillin is offline
Old 06-16-2006 | 07:54 PM
Prater's Avatar
I ground out all the screw holes and pluged a few larger ones then covered with Marine Tex. Lots of sanding to do now. I also took some 800 Wet sandpaper to the mufflers and got them cleaned up better. still need some work but my sanding arm has give out...
ready for sanding
Prater is offline
Double R Performance
Nor-Tech
1
08-02-2006 11:34 AM
Dave98
Powerquest
20
05-15-2005 07:38 PM
BAJA WILL
04-23-2004 08:00 AM
poolshrk
04-07-2004 06:42 AM
Dutrasystem
Superboat
9
08-01-2003 02:01 PM
