Upgraded / aftermarket rotors for F-250 >
Old 06-14-2006 | 08:08 PM
berns29scarab's Avatar
Default Upgraded / aftermarket rotors for F-250
Does anyone have any experience with slotted or cross drilled rotors on the tow vehicles. I have a 99 F-250 with 120hp chip, intake and exhaust and tow my 30 Spectre on a steel trailer couple times a week and want to improve breaking. Suggestions ?
berns29scarab is offline
Old 06-14-2006 | 08:29 PM
Default Re: Upgraded / aftermarket rotors for F-250
Buy a bigger truck........sounds like a good idea and you can get carlos in the shop to do it....just make sure the instructions are in espanol...
Byrdman is offline
Old 06-15-2006 | 09:43 AM
David's Avatar
http://www.dieselperformanceparts.com/index.html
Click on the Ford truck, and use the pulldown menus
David is offline
Old 06-15-2006 | 11:09 AM
tired of warped rotors? had the same challenge on my 99, the cyrogenic [sp?] treated rotors that were also slotted helped a lot, good luck
Bottomfeeder is offline
Old 06-15-2006 | 12:49 PM
David's Avatar
Make sure you torque the lugs correctly, as well. Wrong torque has been known to create rotor issues. I believe there is a company called A.R.T. that also carries cryo treated rotors.
David is offline
Old 06-15-2006 | 12:55 PM
i know of a company that will cryo treat anything you sent them...i believe the name is like 300 Below or something like that
Old 06-15-2006 | 01:32 PM
pachangalpina's Avatar
Cross drilling may look cool but for your application it can decrease the braking. You will be taking away material from the rotor and will make it lighter. Less material on the rotor will be less to assist stopping. Also many of the cross drilled and slotted rotors are made from materials that are inferior to the factory rotors. The easiest improvement that you can make is to upgrade the pad compound. The factory will compromise the pads for noise, dust and performance. The better performing pads may dust more and be noisier. If you want the best brake package without making caliper and wheel changes, look at the Performance Friction website. www.performancefriction.com We are a major distributor for them and supply a tremendous amount of their product to various dealers. Their kit consist of a high quality US made rotor (no slotting or drilling) with a separate rotor hat and pads matched to the rotor and application. The nice thing about the 2 piece rotor design is that it allows you to replace just the rotor the next time. The rotor supplied in the kit is made by Performance Friction but other quality rotors are available from several sources and the rotor is a standard configuration since the hat is separate.
Cryo treatment does make a difference. The poorer the quality of the rotor, the bigger difference it will make. It generally does not increase performance as much as it increases the life of the rotor and resistance to warping.
Let me know if you are interested in the Perf Friction components and I will see what we can do to help.
Todd
Outlaw Disc Brakes
pachangalpina is offline
Old 06-16-2006 | 07:07 AM
Todd
Outlaw Disc Brakes
How much for my application. 1999 Ford F-250 Xtra cab 4x4 7.3 Powerstroke?
Old 06-16-2006 | 09:48 AM
Sent an email.
Thanks,
Todd Howerton
Outlaw Disc Brakes
Outlaw Performance Products
770-844-1777
Old 06-20-2006 | 06:04 PM
klmken's Avatar
Todd,
I'm nearing a brake job on my '04 Excursion 6 liter...towing my 22' Pachanga isn't real taxing on the brakes but I'd love better all around stopping power l(ots of idiot drivers here in the Nations capitol...)
Can you shoot me an e-mail or PM?
Thanks,
Ken
klmken is offline
