Hydromotive Thrust Washer >
Old 06-15-2006 | 11:52 AM
onesickpantera's Avatar
Default Hydromotive Thrust Washer
I just picked up a used Quad IV prop which should be here tomorrow. Do these use a standard Mercruiser thrust washer? Just want to be prepared as I am hoping to cut out of work early and do some testing!
onesickpantera is offline
Old 06-15-2006 | 03:10 PM
throttleup's Avatar
Default Re: Hydromotive Thrust Washer
Yes, same as any Mercury but you will need the old style aft adapter if you don't have one already. It has a castellated top and about 1/8" of splines on the other side.
throttleup is offline
Old 06-15-2006 | 06:37 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Hydromotive Thrust Washer
Part number
31211Q03
[email protected]
bbladesprops is offline
Old 07-19-2014 | 06:45 PM
the ones i have have the hub built into the props. i didnt realize i needed such an adapter. now i am a little pissed because it is saturday afternoon and everybody is frickin closed.
c_loud is offline
twisted switzer
Prop Talk
11
06-09-2010 12:02 PM
jeff1000man
Prop Talk
2
05-02-2007 02:19 PM
1BIGJIM
Prop Talk
3
05-09-2006 09:30 AM
Fuhgedaboudit
0
06-13-2004 01:05 PM
duunoit
2
06-06-2003 01:36 PM
