Setting the timing on a 502 Mag Fuel Inj
Is there anything special that need to be done to a Fuel Injected 502 to set the timing? I am guessing something needs to be unplugged or capped off like on a car.
If you do not have a plug with the jumper wire to plug into the data plug, then you can use a paperclip. Start the engine, then insert a bent paperclip into the terminals labeled A and B. This will put the computer in base timing mode. Now set the timing to 8 deg. You may have to raise the rpm to about 1500 to stabilize the timing. When it is set, remove the paperclip.
Where is the plug?
Registered User
Originally Posted by duksrule
Where is the plug?
#5 in the picture
http://www.mercruiserparts.com/Show_...NESS+%28EFI%29
I found it:
http://www.offshoreonly.com/forums/s...d.php?t=103342
It even has a picture of the plug with pins A and B shown.
