SPARK PLUG suggestions... >
Old 06-16-2006 | 07:59 AM
Blue by You's Avatar
FIERCE ALLEGIANCE
Default SPARK PLUG suggestions...
I've rebuilt both the top & bottom ends of my HP500's with mild components. Dart Iron Heads (308cc Intk vol.) & Intakes, crane 731 CAM all new valves, lifters, pistons, etc & CMI E-tops headers, all new Crane Ignition, coils, etc. We're staying with the stock carb and rejetting back to stock. Not exactly sure of the HP they're going to produce, but we're estimating to be around 530-560. Knowing this, what spark plug suggestions are out there?
Blue by You is offline
Old 06-16-2006 | 11:35 AM
Wobble's Avatar
SORE MEMBER
Default Re: SPARK PLUG suggestions...
I run NGK v-power 5674-9 on a similar 600HP motor, if your heads are taper seat spark plugs, this should be a good choice.
.033 to .035 gap.
Wobble is offline
Old 06-19-2006 | 08:21 AM
FIERCE ALLEGIANCE
Should the spark plug choice be run by Dart? Since it's their heads?
bleachers
Do It Yourself, Boating on a Budget
3
07-25-2008 09:59 AM
gripit
7
04-01-2007 09:57 PM
gripit
8
03-25-2007 10:35 AM
RebarBox
05-31-2003 08:39 PM
Dave1972
12-29-2002 09:38 PM
