Go Back  Offshoreonly.com > Owners Forum > Sunsation
more hp- 500efi >
more hp- 500efi
more hp- 500efi
Old 06-17-2006 | 09:10 PM
Registered User
Default more hp- 500efi
I Was In A Poker Run In Pittsburgh This Weekend Running In The Top Three And Need To Squeeze Some More Power Out Of My 32 Dominator With 500efi-30" Bravo 1 @5100 Rpm- Gps At 82.8, The Boat Of The Day Was 35' Baja Called Poker Face( What A Beautiful Boat)- They Were Running 85.6 Mph With 525's-i Will Be Running With Them Again In August And Would Like To Run Even With Them, Can Anyone Help Me Get A Little More Out Of My Sunsation?
stsrick is offline
Old 06-18-2006 | 08:07 AM
rainorshine's Avatar
Default Re: more hp- 500efi
I may be wrong, but I would think a Dominator with 500's should run better than 82 and some change. Every test I've read about 32s with 496's the boat ran 82-84mph.
rainorshine is offline
Old 06-18-2006 | 04:52 PM
Mentalpause's Avatar
When I test drove one before I bought mine it ran 87 with 500s.
Mentalpause is offline
Old 06-18-2006 | 06:13 PM
This might be worth a try?
http://www.azspeed-marine.com/hpefimothva.html
together with som better flame arrestors this should give you a bit extra. I have not tryed it my self so I am interested in any feedback.
Hydrolift is offline
Old 06-18-2006 | 06:22 PM
Registered User
I JUST BOUGHT THE 32 IN MARCH THIS YEAR-IT IS STOCK EXCEPT FOR EXHAUST MUFFLER INSERTS. DO YOU THINK THIS COULD BE STEALING SOME HP?IT WAS VERY HOT ABOUT 92. I HAD A FULL TANK WITH 4 PEOPLE,THE BOAT RAN VERY STRONG AND OUT OF 48 BOATS I WAS OUT FRONT FOR MOST OF THE DAY EXCEPT FOR A 27 BLOWN FOUNTAIN AND A 35 POKER RUN KEVLAR BAJA NAMED POKER FACE.- THERE WAS A CIGARETTE AND A DONZI 38ZR A 40 BAJA WITH TRIPPLE 600'S, SO I AM VERY PLEASED, I WOULD LIKE TO KNOW WHAT LITTLE THINGS I CAN DO TO GET A LITTLE MORE OUT OF IT.I HAVE A SET OF 32 LABBED BRAVOS I CAN TRY, BUT I NEED TO GET MORE RPM'S.
stsrick is offline
Old 06-18-2006 | 07:50 PM
It will be interesting to see what the 32s will do. The factory spends a lot of time testing different props so my bet is the 32 will be too much without some other changes.
The Arizona Speed Marine link looked interesting.
Old 06-20-2006 | 08:22 AM
Ran-Dom 32's Avatar
this is a little hard to believe, I suppose its possible in perfect conditions, but they run high 70's on a regular basis. I've outran 496 HO 32's many times with my '96 Dom. with 502/415's best I've ever seen was 79 on GPS. 82/83 is the norm for a 500HP 32 Sun.
Ran-Dom 32 is offline
Old 06-20-2006 | 01:26 PM
Knot 4 Me's Avatar
I rode in Dragonheart's 32 Dominator when it had 496 HO's and with 4 guys it ran 80 MPH GPS on St. Clair during the rally. I also rode in Frank's 32 SS with 496 HO's on St. Clair last year and with 5 of us in the boat it ran 82 - 83 MPH GPS.
Knot 4 Me is offline
Old 06-20-2006 | 02:44 PM
Yep, I was there holding the GPS.
Old 06-30-2006 | 12:50 PM
Canada Jeff's Avatar
Don't waste your money.
if I were you, I would look to the drives. Dominator Scott (not sure if he is a member here or not) installed a pair of Land and Sea stern jacks. A Bravo set back box of sorts. He claimed the boat planed better, handeled better, and was quite a bit faster. Land and Sea no longer makes the box, but there are other products out there. Stellings comes to mind. the set back and a shorter lower should give you 5 mph.
If you want DS e-mail address, I have it. He's a great guy and will answer your questions honestly. Just send me a PM and I'll respond.
Aside from drive and prop work, the biggest problem (if you see it as a problem) are the stock heads on our hp500efi. No matter what you do to the intake and exhaust, the restrcition is in the heads. So head work and a cam will yield results aswell. If you want to go that route.
Canada Jeff is offline
