timing on a blower motor >
Old 06-19-2006 | 07:21 AM
Default timing on a blower motor
What should timing be on a blower motor? The are 540s with 420 mega blowers. Adn they have the v-6 modules in them.
BobbyB is offline
Old 06-19-2006 | 09:49 AM
Biggus's Avatar
Default Re: timing on a blower motor
28 to 30 deg
Biggus is offline
Old 06-19-2006 | 10:24 AM
V-6 is 14 degree module, so you want to set your initial at 14 less than total. ie-16 deg initial=30 total. Probably start aroud 28-30 total and listen for any detonation. May up two or three from there.
ghittner is offline
Old 06-19-2006 | 10:59 AM
A V6 module gives 14* advance on a V6 engine. It gives 8-10* advance on a V8 engine. Set total advance in the 28-30* range.
Griff is offline
Old 06-19-2006 | 12:45 PM
carney's Avatar
28 to 30 is plenty. look at the grounding bar on the spark plug. try not to let the discoloration go around the bend.
carney is offline
Old 06-20-2006 | 04:16 PM
Thanks for the info.
BobbyB is offline
Old 06-20-2006 | 04:31 PM
OldSchool's Avatar
Just advance them until they ping....and then back it off a little.
Just kidding Bobby....Happy Birthday!!!!!!! See you this weekend.
OldSchool is offline
Old 06-20-2006 | 05:03 PM
Panther's Avatar
Frank's Marine Service
On the dyno my exhaust gas temps were way too high at 28*. They made the most power at 36* but have them set at 32* in the boat.
Panther is offline
Old 06-21-2006 | 01:06 AM
Strip Poker 388's Avatar
Rob
You all are to conservitive on timming.I guess it depends on the gas you can get?safer.
Watching the timming curve on my 500efi Mef 3 Whipple on the dyno on the top of the pull it was 35-37.even up to 9 psi Total was set at 36 locked out.We had the same timming in it at 11.5psi on race gas.
On my Scarab motor I dynoed at Oddys racing engines we set it at 35 at 11lbs of boost on 93.
Rob
Strip Poker 388 is offline
Old 06-21-2006 | 01:24 PM
Craig,
Where are you staying this weekend?
BobbyB is offline
Buddy OO
4
06-17-2007 08:20 PM
ghittner
9
02-20-2006 07:58 PM
37Talon
11
12-04-2005 10:07 AM
boot
10
05-15-2002 09:29 AM
