HiVolume-or- Hi pressure oil pump >
Old 06-19-2006 | 10:45 PM
EYEBURN's Avatar
Default HiVolume-or- Hi pressure oil pump
I am rebuilding the 502 blower motor in my boat and I was wondering if there is concerns using either type of pump? I personally dont care wich one it is but Id like to know what you guys have found and or running? I have the merc 8 Qt pan. Thanks Greg
EYEBURN is offline
Old 06-20-2006 | 07:38 AM
Ted G's Avatar
Default Re: HiVolume-or- Hi pressure oil pump
High volume is what you need, pressure that is too high is not your friend. And it takes more horsepower to raise the pressure over what is normally used. Also most blower motors are set up with looser bearing tolerances which will need a lot of volume to keep the pressure normal.
www.cbpba.com
Ted G is offline
Old 06-20-2006 | 09:06 AM
ratman's Avatar
what he said
ratman is offline
Old 06-21-2006 | 01:17 AM
Strip Poker 388's Avatar
Rob
Go thru my little thread ,theres some info on oil pumps and part #;s
hope this helps
rob
http://www.offshoreonly.com/forums/s...ghlight=500efi
Strip Poker 388 is offline
Old 06-21-2006 | 07:59 AM
i use system one pumps on myol blower eng. love them also a pan 10 to 14 is a cheap ins. pol.
eliminatethis is offline
Old 06-21-2006 | 09:20 AM
nocigarette's Avatar
I HAVE HEARD DIFFERENT THINGS ABOUT OIL PRESSURE AND VOLUME...........NO ARGUMENT FROM ME ABOUT VOLUME, BUT I WILL ARGUE ABOUT PRESSURE I LIKE TO SEE 80 POUNDS ALL THE TIME. MY ENGINE BUILDER HOSED ME ON THE PUMP JUST A PLAIN BIG BLOCK PUMP. I GUESS THATS WHY I AM REPLACING THE CAM KNOW.....BUT I DID PUT IN THE MOROSSO BILLIT PUMP AND SHIMMED THE SPRING FOR MORE PRESSURE.....
RESON WHY I LIKE PRESSURE IS BECAUSE OIL OBVIOUSLY GETS HOT IN A MARINE ENGINE, NO SHOCKER THERE, SO WHY NOT AT LEAST KEEP BLOWING THE OIL ON THE ROTATING PARTS EVEN IF IT IS HOT.
aGREED THAT TO MUCH WILL CAUSE A BLOW BY BUT AT LEAST IT IS STILL TOUCHING THE PARTS THAT NEED IT.....
IF I AM WRONG JUST KICK ME IN THE NUTS IF YOU EVER SEE ME......
REBUTTLE PLEASE//////////
nocigarette is offline
Old 06-21-2006 | 09:36 AM
Rob
I was told by a few well known engine builders that the BBC does not have a oiling prob so why try to fix something thats not broken,.But ya also got to consider that some of us run LOOSE bearing clearances.
Me I run the pump(#) in my thread and my engine is real loose on the bottom end so the pressure is lower still
Old 06-21-2006 | 09:39 AM
Hey Strip,,,,,,,
My Oil Pressure Was At 40 Pounds Cruising And Coming Off Plane It Would Drop To 15 That Pump Was Just Stock Due You Think I Wasted Money On TheNEW Pump
Old 06-21-2006 | 09:41 AM
Wobble's Avatar
SORE MEMBER
Originally Posted by nocigarette
Hey Strip,,,,,,,
Try the M-1 v-twin 20/50, you will be amazed at the improvement in hot oil pressure.
I'm assuming that you know your oil temps and that they are reasonable.
Wobble is offline
Old 06-21-2006 | 09:45 AM
Yes There Resonable, How Are Ya Wobble........
I Am Not Trying To Sound Like I Konw Anything Just Sharing My Expierience With My Motor
