Prop Tourque Lbs????? Bravo One drive. >
Old 06-21-2006 | 10:00 PM
G Man's Avatar
Default Prop Tourque Lbs????? Bravo One drive.
what pounds should I tourque the prop nut on a Bravo dirve
G Man is offline
Old 06-22-2006 | 12:29 AM
Default Re: Prop Tourque Lbs????? Bravo One drive.
The manual says minimum 55 ft-lbs. Given the size of the shaft, I would think that 75 ft-lbs would be okay, but I wouldn't want to go any higher. Right hand turn drive will tend to loosen the prop nut, so it is a good idea to check the torque periodically and to replace the nylock propshaft nut if it is loosening up. The nylock part will wear out over time.
Garrett
FormulaM2Formula is offline
Old 06-22-2006 | 01:28 AM
Solid hub at 70#
Plastic hub at 35#
Griff is offline
Old 06-22-2006 | 10:18 AM
Grog's Avatar
I just got my new B1 prop with Flo torque hub. Directions say 55#.
Grog is offline
Cignificant
Prop Talk
2
09-27-2006 08:07 AM
diggerman
09-03-2006 09:22 PM
Harper220
3
04-14-2005 03:18 PM
lucky strike
3
06-19-2004 06:46 PM
C_Spray
02-05-2004 10:34 AM
