Props for 540 application? >
Old 06-28-2006 | 09:49 AM
Rebel_Heart's Avatar
Default Props for 540 application?
Under General Q & A, I have a recent thread entitled Dyno - result of 540s. BBlades do you still recommend a Bravo 30? Throttle Up - Matt, I am still waiting for a call from a message that I left on Monday to get your recommendation. Thanks.
Rebel_Heart is offline
Old 06-28-2006 | 12:27 PM
Default Re: Props for 540 application?
What did you have before? EngineHP, WOT rpm, speed, prop?
cobra marty is offline
Old 06-28-2006 | 08:17 PM
Before, I had 502 mpi's (415 hp) at 5000 rpm 74 mph. 26 hydro quad 4s.
Old 06-29-2006 | 12:02 AM
articfriends's Avatar
Looking at the online prop caulator site it shows with same props at same % of slip at 5800 you should be going 84-85mph. Figuring your old motors were 415's BUT gross flywheel hp was actually around 450hp,new motors detuned slightly off dyno may be closer to 650 then 700 you might want to see how it acts with new motors in the midrange and top end with the old props,you'll probably end up with some modfied 28 pitch prop. When I raised the hp in my single v from 750 ish to just under 950 I was SURE I'd be going from my 30 pitch labbed to a 32 pitch,but I ended up just turning the 30 pitch close to 6000 instead of the 5000-5200 it used to turn,the 32 pitch just sits on the shelf collecting dust unless I run with a fairly light load,Smitty
articfriends is offline
Old 06-29-2006 | 11:43 AM
Ran-Dom 32's Avatar
Rebel, have you had your boat out yet? BBlades is working on a set of 30's for my set up. (which is very close to yours aside from the -2 lowers) your engines make a bit more power then mine but I'm willing to bet you will run the best with a 30P B1 prop.
Ran-Dom 32 is offline
Old 06-29-2006 | 01:04 PM
Boat is tested tomorrow morning 6/30 with 29 Quad 4's. Trying to get the 30 Bravo's from BBlades for a trial. They haven't been returned yet. Then I will have a comparison. Will have to change props when I put -2" lowers on?
Thanks for the input.
Old 06-29-2006 | 01:38 PM
Ran-Dom 32's Avatar
my guess is 30's will work with current set up & 32's will be in order with the -2 lower. (I went from 28's to 30's with the - 2 lower swap) GOOD LUCK with the testing & be sure to let me know the results. I'd love to see a back to back comparo. hydro 29 vs B1 30.
Old 06-29-2006 | 01:40 PM
Ran-Dom 32's Avatar
BTW Brett was awsome to deal with for prop trial. (he sent me a set of 32's but they were to big for my set up.) I had them the next day after speaking to him.
Old 06-29-2006 | 06:21 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Props for 540 application?
Sorry for the delay on the test props. Both sets are out and waiting to be returned. I called the customer as discussed and left a voice mail.
I really wanted to see same day back to back testing. However, take good notes per our conversation today and we will learn what the next move should be. I'm still confident in my first recommendation.
[email protected]
bbladesprops is offline
Old 06-30-2006 | 12:00 AM
Sounds good, Brett. I will keep you informed. Thanks.
