outdrive u-joints >
outdrive u-joints
outdrive u-joints
Old 06-28-2006 | 03:38 PM
JLAY's Avatar
Question outdrive u-joints
What is involved in changing the u-joints on a bravo 1 outdrive. It is a one day deal or should i free my whole weekend up?
JLAY is offline
Old 06-28-2006 | 04:33 PM
Default Re: outdrive u-joints
It should be a half day job for a do-it-yourselfer as long as things go well. You just need to pull your drive, pop the c-clips on the joints, pull the joints and put it back together in reverse order. Make sure that you grease things up and inspect your gimble bearing and bellows while you're in there.
Good luck,
Rene
oldandtired is offline
Old 06-28-2006 | 08:09 PM
bowtie's Avatar
Thats true if it's an older drive but if there are no grease fittings and the clips are on the outside of the yoke instead of inside, you better have the right tools or just order the entire assembly.
bowtie is offline
Old 06-30-2006 | 10:48 AM
JLAY's Avatar
How hard is it to disconnect all of the steering cables etc. Should i get the joints from a mercury dealer or can i get it from an automotive shop?
JLAY is offline
Old 06-30-2006 | 01:01 PM
why would you disconnect steering cables?
1. Pull prop so it doesn't get dinged up during handling with out a stand.
2. Pull off plastic caps, take off one nut and slide out trim ram shaft while supporting drive weight.
3. Loosen up the six nuts holding drive on, then slide back about 1 inch
4. Disconnect shift linkage by opening up jaws.
5. Slide off drive, get ready to hang on to the drive shaft otherwise it will fall out of the coupler and hit.
As far as changing the u-joints, my mechanic i use told me that i shouldn't try it, that i could screw up the yokes, said they were pressed in, but there was someone on here that said the early drives had c-clips. So not sure now. I have a 90 bravo 1, clips or pressed in?
cloudmaster_321 is offline
Old 06-30-2006 | 01:53 PM
Let me know if you need this...http://www.offshoreonly.com/classifi...2&cat=5&page=9
Pure Energy is offline
Old 06-30-2006 | 02:05 PM
JLAY's Avatar
Thanks i saw it in the swap shop. Probably about the same price as just the u joints. I have a '93 B1. Wanted to change the joints just to stay on top of things. It does not seem that it is to involved. Now i just have to find a mercury dealer around that is open. I meant to say shifting cables not steering cables, sorry about that.
JLAY is offline
Old 06-30-2006 | 03:37 PM
If you can't find a mercruiser dealer, I am almost 100% that those are automotive universal joints. I am sure that NAPA could help you for about 1/3 the price. I had already bought mine when I looked at the new ones and realized that I should have gone to NAPA.
Rene
Old 07-01-2006 | 02:38 PM
MnFastBoat's Avatar
Charter Member#157
Originally Posted by Pure Energy
How old is this joint? what year?
Thinking it would be a good quick thing to have around
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 07-01-2006 | 03:02 PM
I bought it for my 1990 Bravo drive but never used it. It's about 3 yrs old. Been sitting in my garage.
