Speed calculation formula >
Old 07-01-2006 | 09:35 AM
CcanDo's Avatar
Default Speed calculation formula
Prop pitch divided by gear ratio,divided by 12",divided by 5,280',times 60 minutes=Factor constant.
Factor constant times engine RPM=Gross speed (no slip)
Known speed divided by Gross calculated speed=% of efficiency.Subtract % of efficiency from 100 to find % of slip.
Example:35"prop pitch w/1.50 gears @ 4600 RPM=101.64 MPH,gross.If net is 94 MPH the efficiency is .9248% and the slip is 7.5 % +/-
The factor constant for the above example is .022096 as found using the above formula.Multiply the factor by any engine RPM to find gross speed,for the example combination.
CcanDo is offline
Old 07-11-2006 | 08:39 PM
Biggus's Avatar
Default Re: Speed calculation formula
The formula that I've used for estimating speed (theoretical speed) is as follows:
RPM X prop pitch x gear ratio x .00094697 = theoretical speed
Example, 5600 rpm x 26 pitch x.667 (decimal equivalent of 1.5:1) x .00094697 = 91.9 mph. Actual speed, 81.8 = 11% slip.
I'm not a math wiz, how accurate is this formula?
Kurt
Biggus is offline
Old 07-11-2006 | 10:50 PM
GOODT's Avatar
that formula doesnt allow for 3 or 4 blade or hull wieght or dispacement but im still impressed
GOODT is offline
Old 07-12-2006 | 05:54 AM
BajaRunner's Avatar
why would it need to? thats where the slip factor comes into play.
BajaRunner is offline
Old 07-12-2006 | 06:14 AM
offshoredrillin's Avatar
just use this courtesy of BAM..
http://www.go-fast.com/boat_speed_predictions.htm
offshoredrillin is offline
Old 07-12-2006 | 08:14 AM
Biggus's Avatar
Ttt
Biggus is offline
Old 07-12-2006 | 08:44 AM
Underdog88's Avatar
Veteran: Navy
Try this one...
http://continuouswave.com/cgi-bin/crouchcalc.pl
Underdog88 is offline
Old 07-12-2006 | 09:40 AM
Biggus's Avatar
I'm somewhat familiar with Crouch's formula for calculating speed but does anyone have Crouch's formula for determining the hull efficiency factor?
The hull factor of 180 in the above link is for a Boston Whaler. I think that a stepped bottom v hull would be about 220
Good stuff, thanks for the link!
Kurt
Biggus is offline
Old 07-12-2006 | 12:17 PM
Underdog88's Avatar
Veteran: Navy
Mine worked out to about 215 by filling in the other known fields. Velocity 30 w/pad.
darell
02-15-2008 09:37 AM
fastlane40
Prop Talk
19
08-28-2007 12:51 PM
Rebel_Heart
8
03-04-2006 05:36 PM
Formula Outlaw
12-22-2003 10:11 PM
Hot Boat
19
07-28-2002 08:58 PM
