What's the best way to flush out a holding tank? >
Old 07-04-2006 | 11:22 PM
Default What's the best way to flush out a holding tank?
I've heard that bleach is the way to go, but how much and at what concetrate to water?
Sight and Sound is offline
Old 07-04-2006 | 11:23 PM
Default Re: What's the best way to flush out a holding tank?
...A fresh water holding tank that is!
Old 07-05-2006 | 05:55 AM
100:1 is what we use to clean things up around the firehouse. Try that 1st. Then add more bleach as needed
otis311 is offline
Old 07-05-2006 | 08:40 AM
Scott's Avatar
Charter Member #30
When you get it cleaned out and re-fill use Aquatabs per instructions to keep it fresh.
BTW treat it like anything else that needs "shocked" I would drain the tank and dump in a gallon of bleach then fill it up and let it sit for an hour or so then run the water through all the plumbing to Kill the bacteria. Let it run dry and flush it a few times. When you end up with clear water that you trust add the aquatabs and forget about it.
I did not find a website but you can buy them at West Marine.
I have Steps & Bubbles!
Scott is offline
Old 07-05-2006 | 05:28 PM
Great! Thanks for all the help!
never enuff
Do It Yourself, Boating on a Budget
2
07-24-2008 07:21 AM
Sydwayz
08-21-2006 10:45 AM
duksrule
1
07-26-2006 07:36 PM
duksrule
5
07-24-2006 01:41 PM
Scott
Powerquest
8
07-19-2004 08:14 PM
