What RPM's (max) should I be turning with my 350 Magnums? >
Old 07-05-2006 | 03:30 PM
2 Trick Rick's Avatar
Racer
Default What RPM's (max) should I be turning with my 350 Magnums?
29 Scarab with twin 350/300hp Magnums. I'm having a problem getting over 4800rpm. If I trim the drives to pick up the lost R's I loose speed?
I'm stuck at 66.50mph - I did hit 70.03 @ 5100/52rpm but that was only once and I have yet to do it again
2 Trick Rick is offline
Old 07-05-2006 | 04:34 PM
vandeano's Avatar
Default Re: What RPM's (max) should I be turning with my 350 Magnums?
I may be wrong but I think anything over 5000 rpms is to much for a 350. Even 5000 rpm might be to much for a 350. For a 502 5000 rpm is fine but I thought I read some where a 350 should run at about 4800 max rpm.
vandeano is offline
Old 07-05-2006 | 04:37 PM
Racer
Wellcraft said 5150 rpm is perfect - (Those little chevy's spin like 2-strokes)
Old 07-05-2006 | 07:24 PM
Pwrbt33's Avatar
I just looked it up in my manual and the max rpm for the 350/300 is 5000 rpm. If you are spinning it over that I would be careful of valve float and springs. The actual rpm range is 4600-5000.
John S.
Pwrbt33 is offline
Old 07-05-2006 | 08:38 PM
hunster's Avatar
Carb mags , 46-4800. Mag mpi's 5000. 66.5 mph is all we get! Running 23 mirage + W/mpi mags. Mag mpi's are rev limited I believe. Try running with the tide and you may break 70 again!
hunster is offline
Old 07-06-2006 | 10:02 AM
Racer
My one 70.01 run was down river, wind at my back with a light load of fuel and light wife ...
But I'm still missing 200rpm ?? That could be another 1.5mph
Off to the prop shop
Old 07-06-2006 | 10:06 AM
hunster's Avatar
Sounds to me like it's running good. Fill it up , go out for a ride and have fun. Don't leave it pegged at the max for too long or you'll be replacing those motors sooner than you need to!
hunster is offline
Old 07-06-2006 | 10:17 AM
CB-BLR's Avatar
Chris
Small blocks like to rev to about 5200. -- They just sound happiest there.
CB-BLR is offline
Old 07-06-2006 | 10:21 AM
Racer
Skip it, I just looked at my Gas Receipts from the weekend 3000rpm works best for me now.....
Old 07-06-2006 | 10:28 AM
GOODT's Avatar
LMAO
GOODT is offline
