Holley Fuel Pump Turning inlet Outlets >
Old 07-05-2006 | 11:02 PM
Default Holley Fuel Pump Turning inlet Outlets
Have a high capacity holley mech fuel pump 120GPH with 1/2" inlet/outlet want to put on a markIV 454 with a supercharger. The suction side inlet is marked with IN on casting and is 180 degrees out from what I need for my fuel line set up. Any reason I can't disassemble by removing cap screws and rotate 180 degrees and reinstall cap screws? Anything special I need to know about disassembly and reassembly of this fuel pump. Are gaskets reuseable. I assume just torque screws alternating sides. Will everything work OK after the 180 deg rotation.
Need advice from someone who has played with these before. Really don't want to get into any leakage or pumping issues.
Thanks,
Vmax
Vmax is offline
Old 07-06-2006 | 07:53 AM
monstaaa's Avatar
Default Re: Holley Fuel Pump Turning inlet Outlets
there should not be any issues in doing such. just be careful not to tear the diaphram ofcourse, and watch for debri,
good luck
monstaaa is offline
Old 07-06-2006 | 09:01 AM
mopower's Avatar
Toxic FORMULA
Done it , no problem
mopower is offline
ak
5
04-13-2008 08:14 PM
jdub
7
03-26-2007 05:06 PM
zitoracing
0
10-15-2006 01:37 PM
djtalon
1
04-24-2006 06:05 AM
Leathl_WS6
8
10-13-2003 04:59 PM
