What length alternator v-belt do I need for a 350..... >
Old 07-06-2006 | 11:33 PM
klmken's Avatar
Default What length alternator v-belt do I need for a 350.....
Found out the boat will run a while with out the alternator.....
klmken is offline
Old 07-07-2006 | 05:42 AM
Iggy's Avatar
Default Re: What length alternator v-belt do I need for a 350.....
It just so happens that I recently replaced one on my 1988 350 MAG.
Still had the old one in my truck. The Merc p/n on it is 57-93658 then there is a series of numbers "3:C:11:2".
I don't recall just what they mean, try searching for that info.
But I can tell you that the circumference (not diameter) is 44".
I installed a new 100 amp alternator and found that the housing was larger than the original unit. It hit the motor mount bracket limiting belt adjustment to about 1" of travel. I had to find a smaller circumference belt to fit.
Hope this helps.
Iggy is offline
GO4BROKE
15
06-08-2008 07:33 PM
Iggy
4
04-17-2006 06:09 PM
synack
1
02-17-2006 07:59 PM
berns29scarab
05-31-2005 09:36 AM
26sonic
2
04-25-2003 07:12 AM
