motor problem
Old 07-07-2006 | 01:56 PM
Default motor problem
Ive got a gen 5 carbed 454, 420HP that has a little issue... it will start up in the morning, i can run it to lunch (about an hr) turn off the motor and eat lunch (about 1.5hrs), go to the boat and it starts right up, but then i go and anchor out, let it sit about 4 hrs, and it wont start, the 4 hours it sits is the hottest and most humid part of the day, im thinking it could have soemthing to do with that,
i usually go back to the ramp on one motor, then the next day it will fire right up again in the AM.... any ideas??
Boomer35 is offline
Old 07-07-2006 | 02:07 PM
Wobble's Avatar
SORE MEMBER
Default Re: motor problem
Is the boat rocking a lot when anchored? could be a fuel float issue causing the motor to flood.
Could water be running of the hatch and getting the ignition wet (from swimmers)
Wobble is offline
Old 07-07-2006 | 02:10 PM
gripit's Avatar
You have to be more specific with your symtoms. Does it crank, clicking noise, or???
gripit is offline
Old 07-07-2006 | 02:26 PM
36spectre's Avatar
Registered User
swap out the coil .....
36spectre is offline
Old 07-07-2006 | 02:29 PM
Your not taking a long enough lunch !!
otis311 is offline
Old 07-07-2006 | 02:45 PM
Panther's Avatar
Frank's Marine Service
I've seen the fuel vapor lock when it's hot, just a suggestion.
Panther is offline
Old 07-07-2006 | 03:49 PM
dean51267's Avatar
that was my first thouht...
dean51267 is offline
Old 07-07-2006 | 04:08 PM
MitchStellin's Avatar
It sounds like vapor lock, usually a coil goes all at once, no hit or miss, it could also be the slave solinoid, does it click once when the key is turned but not engage the starter? It sounds like a vapor lock the more I think of it but after 4 hours that should clear. If the engine is hot the fuel will boil and vaporize and leave a pocket of air that locks the fuel system. On the slave, you can turn it and hear a click, keep doing it and it may fire but most of the time they have moisture in them. It is very common after storage to have this go out. This is a fun one to find, you can swap out the entire electrical system and find it is fuel or the other way around. I would say fuel though, maybe lift the hatch while sitting, run the blower to pull the hot air out. Still 4 hours is enough time to let this rest.
MitchStellin is offline
Old 07-08-2006 | 12:17 AM
jeff32's Avatar
I'm not a mecanic to that point, but I would think float problem... I'd switch the carb first. Does not take too long to do it!
jeff32 is offline
Old 07-09-2006 | 06:39 AM
36spectre's Avatar
Registered User
coil swap is easier and faster than swapping carbs.....
