1998 baja outlaw with 502 mag mpi top speed ?? >
Old 07-08-2006 | 11:12 PM
Default 1998 baja outlaw with 502 mag mpi top speed ??
i just got the boat friday. only goes 60 mph at 5000 rpm.
i feel it is smooth like a honda ! no sudden power or feel at all... maybe the motor isnot going right..way too smooth !
arent they supposed to be faster ? like 73-75 mph ?
chevalcabre is offline
Old 07-09-2006 | 02:42 AM
Playn's Avatar
Default Re: 1998 baja outlaw with 502 mag mpi top speed ??
I'm assuming a 25' outlaw w/ a single 502 mag (415hp). Dry weight is 4750# so with say 1/2 fuel (50 gal) call it 350#, a couple guys (say 400#) your at 5500#. What are you running a 23p prop? My guess would be very low 60's at best. 73-75mph? no way
Playn is offline
Old 07-09-2006 | 09:47 AM
liquid asset's Avatar
should run 65-68 if it is running light at a low elevation, and trimmed out , If its at high elevation and hot that may be all she'll do, where did you test
liquid asset is offline
Old 07-09-2006 | 12:59 PM
articfriends's Avatar
Everyone throws big numbers around with these boats (67-72) but around here at 600-900 feet elevation and fresh water a bone stocker runs 60-64 depending on fuel load and passengers. Full tk of gas,4 passengers-60-62 mph,I run the 70 mph ones ALL the time and surprizingly they only run low 60's pacing them with my boat on my gps. You probably have a couple mph to be had with propping but don't drive yourself nuts thinking your boat is defective,my 2000 272 with stock 502 mpi only ran 60-65 depending on how much fuel and passengers too,Smitty
articfriends is offline
Old 07-09-2006 | 10:23 PM
today, i realised the trim gage was not working well... i trimmed it right looking at the water line and was able to hit the 70 mph with half tank/3 people ...
i guess everything is fine.. thanks to all.
Old 07-09-2006 | 10:33 PM
cigarette38topgun's Avatar
I had a 1998 25 OL 502mag and the speedo read 70-71 but my garmin gps read 60.1 at her best............low 60's is about right before tinkering with props and such
cigarette38topgun is offline
Old 08-11-2006 | 02:19 PM
why does everyone tslk gps speed that is not even close to being accurate gps positioning is only accurate within 3 meters this can drastically effect your GPS speed readings I used gps garmin172 for my speed and found that i was only doing 60 mph but when we use my cop friends Radar we were going 68 I cant stand when people use gps for speed it is tottaly in accurate
nkdski is offline
Old 08-11-2006 | 02:51 PM
COOL!! That means my GPS 82mph is really closer to 87mph!
kennyo is offline
Old 08-11-2006 | 02:59 PM
Ironmanwb's Avatar
It all depends on how good of a GPS that you have. I have had 3 differnt portables and tested them in my truck. They were all withing 1 mph of what the truck read. The cheaper one was the farthers off at 1 mph but the other two were right on.
The only thing that I found was that while accelleratiing or decellerating it took a few seconds for the gps to match the speed.
My .02.
Ironmanwb is offline
Old 08-11-2006 | 09:51 PM
thisistank's Avatar
You have to remember with Radar you can get cosign effect. Basically the radar is returning at a funky angle and can make for false readings (reads high). If you are running, the best practice is to point it straight ahead at a steady target (large ship, bouy, etc.)
thisistank is offline
