how much oil press is too much >
Old 07-10-2006 | 12:12 PM
troc's Avatar
Default how much oil press is too much
Anybody have any experience with the Maximum psi a BBC can run? Thanks
troc is offline
Old 07-10-2006 | 09:03 PM
Papache's Avatar
Registered User
Default Re: how much oil press is too much
over 100psi is to much
Papache is offline
Old 07-11-2006 | 07:31 AM
troc's Avatar
Thanks, I am running 90 psi when cold @wot then drops to about 75#s I guess I'm good. Thanks for the info.
troc is offline
Old 07-11-2006 | 08:47 AM
nocigarette's Avatar
I Think To Much Pressure Is Horsesheet,under A 100 Is Fine I Run 80-85 Cold And 60 -65 At Wot.........and Most Of The Time It Is Wot............
nocigarette is offline
Old 07-11-2006 | 12:52 PM
Strip Poker 388's Avatar
Rob
If its a non modified melling pump the bypass spring in them is set at 75PSI, maybe the gage is off?
Could Your bearing clearances be tight?
Strip Poker 388 is offline
Old 07-11-2006 | 05:47 PM
I have the blue spring in the pump. Main and rod clearances are at mercury recomended minimum,new cam bearings. I guess the gauge could be off, can check with mechanical. Would you see pressure surging as relief spring
popped off and on?
mascarab is offline
Old 07-11-2006 | 06:01 PM
Rob
Heres a little info on pumps in this thread
http://www.offshoreonly.com/forums/s...t=500efi+build..
All my electric sending unit gages I have cked are off. Even after sending my Livorsi fuel pressure gages and senders back to Livorsi to get calibrated to the senders $$$$$. One is off 14PSI the other one is 6 psi off. I just use them as a reference to see if there is a prob now.
Old 07-11-2006 | 07:33 PM
blue thunder's Avatar
That's right strip poker. Excess pressure is dumped out the pressure relief. The more over the pressure limit the more oil dumped. The problem in my limited opinion is that this dumped oil drops directly out of the pump and back down to the pickup area. This oil goes around and around getting hotter and hotter thereby possibly cause oil temp issues. That is my take on too much oil pressure. Ideal is probably a little over pressure relief cold to help build temp, then a little under that value hot. Over the pressure relief value hot would be a problem.
BT
blue thunder is offline
Old 07-11-2006 | 10:44 PM
Rob
BT
another thing I tought about the more oil being bypassed is getting aerated and slung around ,so double the HP lost,
Also the way mine is set if real loose on bearing clearance its slinging more oil around,low oil pressure but Ive got that cushion, also a good oil pan. I guess there's always a trade off.Like some professional engine builders told me I am over thinking the oil system on a BBC, They said they work fine asis,but it cant hurt
I had a SBC drag motor with high oil press once 90 cold it broke a Moroso Dist hold down clamp stud, the resistance just pushed the dist out Maybe that's why the make better oil pump drive shafts
Rob
BY U BOY
Scarab
0
04-27-2008 09:42 PM
madbouyz
4
01-14-2003 10:16 AM
jcap
9
09-25-2002 09:35 PM
C_Spray
7
06-17-2002 10:07 PM
