turning my 454 mag into 525sc >
Old 07-11-2006 | 12:25 PM
Default turning my 454 mag into 525sc
looking into turning my 454 mag into a 525sc,wanted to know what parts are the same and what i would need,blower,carb jet size,camshaft,is the compression the same,cylinder heads the same,fuel pump?
awsomethunder is offline
Old 07-11-2006 | 01:53 PM
Default Re: turning my 454 mag into 525sc
Crane cam #132561
Roller rockers
Gil or CMI exhaust
Comp ratio is 7.5:1
Ignition Module
You could easily just bolt on a 525sc intake, blower and carb package. Just increase the pulley size and lower the boost a little to compensate for the higher compression. Stock boost is 5.5#
Griff is offline
Old 07-11-2006 | 03:02 PM
I would run a 1050 dominator. Dont think the stock one will be big enough.
Wildchild212 is offline
Old 07-11-2006 | 03:21 PM
razor1115's Avatar
I think that is what is on the 525SC...
razor1115 is offline
Old 07-11-2006 | 06:12 PM
Scarab3DMC's Avatar
Ijust sold 2 complete 525 S/C blower packages to Double R Marine they are dialed in and ready to go..he's putting them in stock,,,give Raymond a call..
Attached Thumbnails turning my 454 mag into 525sc-0c4e265c-d73b-1c31-6817d2948e757fce.jpg
Scarab3DMC is offline
Old 07-12-2006 | 01:58 PM
SSComp's Avatar
Did exactly what you are looking to do...I'll see if I can dig up a parts list.
SSComp is offline
Old 07-13-2006 | 06:01 AM
Call Tyler Crockett, he'll sell you the cam and do the headwork you'll need. He did this for me and it turned out beautiful. The motors were awesome from power to the idle. He set up the carbs for me and they idled and accelerated like EFI. I sold the boat and I don't have the specs anymore. He works with Quick Fuel on carburetors. He set up modified 850's boost referenced for me. Much cheaper than the dominators. They build what you need and test run each carb. Tyler will sell you the components you need at a good price and give you the tech support you'll need to avoid problems. He recommends mild rework of the head, bowl work, seats, guides, valves, etc...he will do, crossover, exhaust upgrade, MSD ignition, Fel-Pro head gaskets. I went with custom CNC Brodix heads although Tyler said it wasn't a cost effective upgrade. He said my package would be 650hp. I never dynoed but my speed increase would indicate this to be accurate.
Attached Thumbnails turning my 454 mag into 525sc-webphoto454650out.jpg   turning my 454 mag into 525sc-webmotorcomplete.jpg   turning my 454 mag into 525sc-webstarboardmotor.jpg
SkiDoc is offline
Old 07-13-2006 | 06:38 AM
eagle did you go from 454 mags and how much speed did you gain with the conversion?
Old 07-13-2006 | 10:35 PM
Went from 74 to 97 gps on 97 Eliminator Daytona. Were 454 Mags.
SkiDoc is offline
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
awsomethunder
10
06-20-2007 10:31 AM
RazorsEdge
Superboat
16
08-09-2006 07:42 PM
guillermof
2
08-10-2005 02:24 PM
