alignment of twin bravo drives >
Old 07-11-2006 | 02:35 PM
bblythe's Avatar
Default alignment of twin bravo drives
What is a good way to check and align twin bravo drives with hdy inco steering
bblythe is offline
Old 07-11-2006 | 03:24 PM
Panther's Avatar
Frank's Marine Service
Default Re: alignment of twin bravo drives
Measure center-to-center on the prop shafts and center-to-center of the bullet on the back of the drive. Then adjust for desired toe-in/toe-out.
Panther is offline
Old 07-11-2006 | 03:47 PM
bblythe's Avatar
What the toe in or toe do to the handling of the boat my drive spin outwards
bblythe is offline
Old 07-11-2006 | 03:59 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Toe = Nose cones of leading edge of drive/s.
There's been a couple of posts on different boards relating to the same topic. Many, many different opinions, as usual depending on make model yada-yada. As a "rule of thumb" if drives spin out no more than1/8" toe out (drive cones out further than the propless propshaft measurements).
If props spin inward, toe in no more than an 1/8" (tips of propless shafts out further than the center of cones). Various reasons, but that's the gist.
Start with dead even (cones/shafts exactly the same distance apart) note performance/handling, then work out/in depending on props rotation in 1/16" increments, or if feels great even leave it alone.
Reckless32 is offline
Old 07-11-2006 | 10:05 PM
bblythe's Avatar
Thanks for the help by the way what would be a noticeable change?
bblythe is offline
THE OUTLAW
Drives and Lower Units
8
06-11-2008 12:07 PM
QUIKDECISION
4
08-10-2005 12:13 AM
LHC30Victory
6
12-29-2003 11:42 AM
garshev
06-11-2002 12:11 AM
Tinkerer
11
04-03-2002 06:53 PM
