What 5 blades >
What 5 blades
What 5 blades
Old 07-11-2006 | 09:23 PM
PWRQWST's Avatar
Default What 5 blades
I have a 99 38 Powerquest with 525sc and 12" boxes 1.5 lowers. I lost a prop last weekend so I am deffinatly ready now. I am wondering which set I should try first. Any thoughts?
Also does anyone have a 4 blade 30 pitch bravo rt turn they may want to sell?
Thanks Rich.
PWRQWST is offline
Old 07-13-2006 | 08:53 AM
throttleup's Avatar
Default Re: What 5 blades
I would recommend a Hydromotive P5-X for your application in a 5B configuration.
Julie
throttleup is offline
Old 07-13-2006 | 01:51 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: What 5 blades
Most every manufacturer or distributor is going to suggest their version.
Food for thought....we developed and tested the Maximus propeller on a 38 Powerquest here in Wisconsin.
[email protected]
bbladesprops is offline
Old 07-19-2006 | 10:47 PM
PWRQWST's Avatar
I will let you know in a couple of weeks going on vaca and trying some 4 blades then I want to try 5 blades
Thanks Rich.
PWRQWST is offline
Old 07-24-2006 | 09:00 PM
performancemary's Avatar
Pressurized
The 2001 38' PQ test boat Blades is talking about is mine. I am currentlly using a set of the Maximus 32'' lab finished by Merc. Have stock 575sci's and XR drives. Best run to date was 84 at 4950 /5000 RPM.
performancemary is offline
Old 07-27-2006 | 05:07 PM
sea-crit
I'm running a set of Maximus 15 1/4x 28p labbed by Merc on a 99 382 Formula with 500+ EFI. Best run 77 @ 5000
Old 07-31-2006 | 09:08 PM
PWRQWST's Avatar
Ok ran a set of 34 pitch recupped to 32 and labbed this past week and they sucked on my boat I could not get it on plane at all and way to much slip I ran 72 MPH at 5450 rpm What pitch do you feel I need, if I go 5 blades. Thanks.
Rich.
PWRQWST is offline
Old 08-01-2006 | 07:12 AM
throttleup's Avatar
It depends on the manufacturer. What rpm and speed were you running with the stock 30's before it got lost?
You may need something in the 29 range from Hydromotive or a 30 Maximus.
Matt
Old 08-01-2006 | 03:26 PM
PWRQWST's Avatar
Matt
I ran 78.6 gps at 5250 rpm with the 30 4 blades I also ran a set 0f 3 blade 28 labbed and ran 73 at 5250 but had a better hole shot and mid range then with the 30's. Let me know your phone# and I will call you. Thanks
Rich.
PWRQWST is offline
Old 08-01-2006 | 03:35 PM
throttleup's Avatar
Rich we can be reached at 727 531 2255 our web site is www.throttle-up.com
