CMI Header install >
CMI Header install
CMI Header install
Old 07-12-2006 | 01:52 AM
Default CMI Header install
I am currently installing the CMI 496 sport tube on my Volvo 496 motor. Do I need to apply any kind of thread locking compound on the ARP bolts? If so - what type?
Any input would be greatly appreciated.
Regards
Bengt B
bengtb is offline
Old 07-12-2006 | 07:30 AM
GOODT's Avatar
Default Re: CMI Header install
no
GOODT is offline
Old 07-12-2006 | 12:54 PM
Thank you for the info Joe. Could you tell anything on the torque for these bolts?
Bengt
bengtb is offline
Old 07-13-2006 | 11:38 PM
OSO's Avatar
OSO
Regards
Bengt B
don't forget to re-tighten them after you run the motor the first time or two.
OSO is offline
Old 07-15-2006 | 07:06 AM
GOODT's Avatar
this is VERY IMPORTANT !!!!!!!!
the reason for not putting any thing on them is it you use loctile and they do heat up the lock tite will have the oppisite effect as desired and if you use a lube they wont stay tight ....just be sure as OSO says to re tighten them after first hour then I like to double check them at least once a yr
GOODT is offline
Old 07-15-2006 | 07:12 AM
GOODT's Avatar
another word of advice if running in salt or brackish water be sure to flush flush flush.........CMI makes a great product but do not leave salt water sitting in them
GOODT is offline
Old 07-15-2006 | 02:30 PM
Ok Thank you for the input. I noticed that the screws where quite loose after the first run. I suppose I wil check regularly for at least the first few runs.
bengtb is offline
Old 07-15-2006 | 09:17 PM
Elite Marine's Avatar
Check then every so often, not just after the first few runs.
Elite Marine is offline
Old 07-17-2006 | 01:34 AM
Do yourself a favor, get some ARP SS studs for the headers. I retightened the bolts all the time for the first season. Installed the studs with new gaskets, retightened once and that was about 100hrs ago.
Griff is offline
Old 07-17-2006 | 05:19 AM
Big Block Billy's Avatar
Smile Re: CMI Header install
ARP Bolts work well , listen to Joe's directions, re-tighten them
and all will be well, BBB
Big Block Billy is offline
custom29scarab
0
08-01-2007 08:26 PM
Rrice
05-14-2007 08:12 PM
30 outlaw 2005
10
06-01-2006 09:45 PM
boatfreak
3
08-20-2005 09:12 AM
Punk Rocket
21
08-07-2002 08:33 AM
