Just got props back from Bblades. Time for testing >
Old 07-12-2006 | 06:42 AM
BajaRunner's Avatar
Default Just got props back from Bblades. Time for testing
I sent a set of props to Bblades to have labbed.
They look awesome! cant wait to try em. Ill post before and after numbers after i run them this weekend.
The boat is a 2000 Baja 36 Outlaw.
BajaRunner is offline
Old 07-12-2006 | 10:13 PM
flyboyaa1's Avatar
Default Re: Just got props back from Bblades. Time for testing
what power are you running and what drives and what are the props pitch that you just had labbed.
flyboyaa1 is offline
Old 07-13-2006 | 07:57 AM
BajaRunner's Avatar
hp500's, bravos, and 26p bravo 1's.
Old 07-13-2006 | 09:52 AM
flyboyaa1's Avatar
sounds good bajarunner I have stock bravo 1 26P on my 35 outlaw. Julie at throttle up is labbing my new bravo 1 28P for me this week i will be trying and testing them next weekend. I was currently running 72 mph on the gps at 5100rpm. im hopping to run 75 mph at 4950 to 5000 rpm on the 28P labbed props. I will keep you posted.
John
Old 07-13-2006 | 09:53 AM
BajaRunner's Avatar
Sounds good. I rev a little higher hence the 26's. Ill be turning them 54-5600. 35 outlaws are a lot faster hull.
Old 07-13-2006 | 10:07 AM
flyboyaa1's Avatar
sounds good keep me posted on your numbers with the new props. I almost went with a 2005 36 outlaw but went with the new 35 outlaw in hopes of keeping the resale value up I think both boat ride good. This is a new hull for baja with the notched transom and a small ride pad in the back Im hope i pick up a little more speed with the labbed 28's I hope I made the right boat choice I liked them both.
John
Old 07-13-2006 | 03:17 PM
flyboyaa1's Avatar
hey bajarunner i was also wanting to know if you have ever swapped your probs and run them turning in and if so what was you experience with that. handling docking speed ?
Old 07-13-2006 | 05:27 PM
He's got my 5 blades up there for some mods.
I can't wait to see how they are going to work.
JaayTeee is offline
Old 07-17-2006 | 06:08 PM
BajaRunner's Avatar
Brett, give me a shout when you get a chance, i left you a message this morning.
Jason
512-848-1951
Old 07-20-2006 | 08:49 AM
Indy's Avatar
Member #154
BajaRunner...how did they perform?
Indy is offline
