trim pump oil whats the best? >
Old 07-13-2006 | 09:59 AM
Default trim pump oil whats the best?
for outdrives
SLINGSHOT is offline
Old 07-13-2006 | 10:24 AM
Wobble's Avatar
SORE MEMBER
Default Re: trim pump oil whats the best?
It's just hydraulic fluid, not much to be gained or lost as heat and duty cycle are not really a factor. I use a clear one by SeaStar(I think) from boat US, less mess if it leaks or spills.
Wobble is offline
Old 07-13-2006 | 01:01 PM
I have 3 pumps the have dark oil and 1 pump with clear oil. I guess you shouldn't mix when topping off??
ActiveFun is offline
Old 07-13-2006 | 01:27 PM
Strip Poker 388's Avatar
Rob
Mine has ATF in them and its dark.
The standard oil put in from the factory is 10w-30 engine oil. The power steering & trim fluid is thinner. It is quieter and faster with the Power trim fluid in it .
I want to flush and change mine to the power trim fluid or a at least a 10 weight oil.
Strip Poker 388 is offline
wrenchman
3
10-06-2006 04:23 PM
CNC
2
06-10-2006 07:36 AM
ratman
01-26-2006 07:48 PM
Lunatic Fringe
0
08-05-2004 03:25 PM
