gear lube resevoir leak
any idea what can be happening? Resevoir slowly looses lube into bilge. I can't see behind the motor but can see it drool down the inside of the transom looking under the motor. line from resevoir is clean to transom plate.
depending on the year there is either a plastic pinch clamp there or A quick connect at the transom or may not be the line at all could be the drive leaking into the bellows then into the boat
