Oil Temps?
What oil temperature is your boat running? I have been running around 220-230. With hard runs and just cruising. Some say this is too high and others say its fine. I am running 540s with 420 mega blowers.
Cruise temps are about 220, hard extended runs temps rise to 260 (measured before cooler) 468" 671's Superchillers 8 lbs boost. Seems to work real well. Currently have close to 300 trouble free hrs on this set up. Recently switched to Mobil 1 15-50. Just bought M-1 V-Twin for the next change.
Originally Posted by BobbyB
Some people say that is good and others say it is bad. Just trying to find out what is good or bad.
Originally Posted by Rebel_Heart
Is there any trick to getting oil temps above 200? Is this dependent on the type of oil used and/or the way you run? It seems difficult for me to achieve those temps.
Also, sometimes using a crossover system instead of regular recirculating pump can cause this 'hard to get to proper oil temp' on some applications.
