Ever had a prop thrust washer break? >
Old 07-16-2006 | 08:30 PM
BajaRunner's Avatar
Default Ever had a prop thrust washer break?
I was testing my new props today. About an 1hr into driving, i heard a pop, almost like a back fire. I stopped, checked the engine and everything seemed fine. I couldnt get the engines to wind up all the way. Got back and one of my props was loose. pulled it off and it grinded into the lower case, and no thrust washer. are they know for breaking??
BajaRunner is offline
Old 07-16-2006 | 09:24 PM
GOODT's Avatar
Default Re: Ever had a prop thrust washer break?
in 25 yrs never seen one break have seen them wear when a prop spins a hub, did someone just put prop on?????
are you sure its not stuck in the back of the prop?????
weird
GOODT is offline
Old 07-16-2006 | 09:37 PM
BajaRunner's Avatar
i put the props on this morning, and the thrust washer was there. i got back, and it wasnt
Old 07-16-2006 | 09:38 PM
BajaRunner's Avatar
weird
yes, it also wore into my lower with its absence.
BajaRunner's Avatar
ill take some pics tomorrow.
Old 07-16-2006 | 09:53 PM
GOODT's Avatar
Ive never seen one just disappear, When I install props I use an batt impact with 180 ftpd and tourque them much more the the specs call for never never had one break what drives are you running ???????
GOODT is offline
Old 07-17-2006 | 01:14 AM
I had this happen before too, well sort of.
Changed props, thrust washer stuck in old prop and I didn't notice, installed new prop during a brain fart
Griff is offline
Old 07-17-2006 | 07:36 AM
BajaRunner's Avatar
Im sure it wasnt in the old prop. Im starting to doubt myself if it was in there. Now im 90% sure (I was 100% ) . It was running good, 5400 rpms, heard a pop, like a backfire. I stopped and checked the engines, everything was good. Started back up, but only to get 5000 rpms. checked it when i pulled the boat out, and found this.
1st one is good side, second bad side
Attached Thumbnails Ever had a prop thrust washer break?-outdrives-001.jpg   Ever had a prop thrust washer break?-outdrives-002.jpg
Old 07-17-2006 | 07:49 AM
GOODT's Avatar
1) if it was in there and broke or shattered the zinc would be scared up and it looks fine to me
2) if it did break it would have broken in to REALLY small pieces to disapear through the prop hub
GOODT is offline
Old 07-17-2006 | 07:59 AM
BajaRunner's Avatar
Any thoughts on the loud, single pop like a backfire, then loosing 400rpms? I really dont think it came from the engines.
You would think rubbing against the outdrive would slow it down quite a bit.
