How much "bow Lift" can you get from a prop? >
Old 07-17-2006 | 07:44 PM
Default How much "bow Lift" can you get from a prop?
I'm looking for more lift on a single 30' narrow beam. I've added a drive spacer and picked up a couple, but the boat still needs more. I can feel the boat slowed by being in the water at speed .
Can labbing a prop make a difference....a noticable one??
I've tried a 5 blade with poor results.
Stock Bravo 1 has performed the best so far.
Pure Energy is offline
Old 07-18-2006 | 11:30 AM
Pat McPherson's Avatar
Default Re: How much "bow Lift" can you get from a prop?
Hey PE,
I have noticed a nice improvement since BBlades altered my Bravo 1 prop.
I'm not sure if the effects would be as great on your larger boat though.
OH-Zone is now running his Bravo 1 that BBlades labbed for him. He should be able to give you some decent data of before and after.
Are you going to be able to meet up with us this Friday? We are leaving Old Saybrook around 5:30pm and will be on you side of the Sound some time after 6pm...
See you soon,
Patrick
Pat McPherson is offline
Old 07-18-2006 | 03:47 PM
throttleup's Avatar
Yes, you can induce more bow lift into any propeller as well as calming down the stern lift when necessary. The 5B props will induce stern lift regardless of blade design so I am not surprised at your results. I think you could increase the bow lift on your Bravo I propeller. This can also be performed on a Lab Finishied propeller, which of course is for speed gains.
Julie
throttleup is offline
Old 07-19-2006 | 07:35 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: How much "bow Lift" can you get from a prop?
We can do many things with the B1 propellers. If you would like to dicuss the options, please give us a call. We do this to Bravo 1 propellers very often.
[email protected]
bbladesprops is offline
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
Freeryd
5
05-15-2008 06:32 PM
IRONMAN
Prop Talk
0
09-28-2006 07:20 PM
stecz20
09-22-2005 01:17 PM
mikesufka
12-26-2002 11:23 AM
