Plexus?
Old 07-17-2006 | 10:50 PM
SOX's Avatar
SOX
Semper Fi
Default Plexus?
What do you think of Plexus? I was looking at the new Baja's on the market which are being built with a liner system joined with Plexus. I am a bit Leary of an adhesive joining the main framework to the hull as well as the deck and hull joint. I have a bit more comfort seeing that Formula is using Plexus to adhere it's stringers as per this link
http://www.plexusasia.com/ind_marine.html
Who else is using Plexus and is it as good as they claim?
SOX is offline
Old 07-17-2006 | 10:53 PM
Default Re: Plexus?
Good stuff, i use it. no probs after 1 year.
Anarchy Powerboats is offline
Old 07-17-2006 | 11:08 PM
DirtyMoney's Avatar
Default Re: Plexus?
Formula has been doing it for a while.
DirtyMoney is offline
Old 07-17-2006 | 11:21 PM
Default Re: Plexus?
oops, the Plexus I use is for cleaning canopies.
Old 07-17-2006 | 11:27 PM
FeverMike's Avatar
Default Re: Plexus?
Plexus (the adhesive) has been in use for a long time. Scarab used it and I know Formula and many other builders use it. It is also used in other industries such as the aerospace industry too.
FeverMike is offline
Old 07-18-2006 | 07:34 AM
CigDaze's Avatar
Default Re: Plexus?
That's right Mike. Boeing is a big purchaser of Plexus.
Plexus makes excellent adhesive systems. They are used by most manufacturers including Formula and Baja among many others. It exhibits great strength, toughness and impact resistance.
http://www.itwplexus.com/home.html
CigDaze is offline
Old 07-18-2006 | 09:42 AM
Wally's Avatar
Were doomed!
Default Re: Plexus?
Plexus bonds at a molecular level....I've actually seen a failure of two panels joined by Plexus.....it wasn't the plexus that failed but the panels themselves broke apart!! the bond was still perfect! Its some cool stuff
-Wally
Wally is offline
