Mirage Plus VS Mercruiser Quicksilver >
Old 07-18-2006 | 09:28 PM
Default Mirage Plus VS Mercruiser Quicksilver
I curently have a Quicksilver 27P I was going to have labbed.
Would I notice much difference if I purchased a Mirage Plus 27P. I understand the Quicksilver is a little more stiff?
1BIGJIM is offline
Old 07-19-2006 | 08:46 AM
throttleup's Avatar
Default Re: Mirage Plus VS Mercruiser Quicksilver
I would reconsider lab finishing your prop. If needed, a reconditioning should be all it needs. Typically you won't see much of a speed gain from a standard Mirage or the older Quicksilver props after lab finishing.
A Mirage Plus 27 will run about 200 rpm less than your Quicksilver.
throttleup is offline
Old 07-19-2006 | 12:16 PM
Why is that? Same speed and less RPM?
Looks likes it time to put the old quicksilver back on Ebay
1BIGJIM is offline
Old 07-19-2006 | 07:18 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Mirage Plus VS Mercruiser Quicksilver
You can gain small amounts from Labbing the Q.S. props. You need to change the Blade area and the geometry and the rewards very.
As far as the standard Mirage, we find big gains if the application has good top speed numbers with rev limiter R's and high slip % by turning them into Plus's.
[email protected]
bbladesprops is offline
jeff1000man
Prop Talk
2
08-31-2007 12:46 PM
2 Trick Rick
Prop Talk
5
09-06-2006 04:37 PM
2 Trick Rick
08-25-2006 10:57 AM
powerguy
Fountain
4
03-28-2006 05:48 AM
onesickpantera
07-16-2005 07:35 PM
