What is the gray wire with the.... >
Old 07-19-2006 | 09:07 AM
Unhappy What is the gray wire with the....
quick connect insulated plug for on the back of the wiring harness of my 1996 502mpi engine for? It comes off the eletrical harness in the back of the engine. It looks to be about 16 or 18 gauge.
I've looked everywhere and can't find any spare empty places for it too plug into. I have all the trim pump working and outdrive reservoir wires plugged in. I just hope I plugged the right combination in to make everything work as it should.
Any help would be appreciated. I'm getting close to putting it in the water for the final tuning.
Thanks,
shawn
29scarab is offline
Old 07-19-2006 | 09:14 AM
Wally's Avatar
Were doomed!
Default Re: What is the gray wire with the....
Gray is usually a tach signal wire.....but this may be the timing wire to put the computer into a base mode to set initial timing...
-Wally
Wally is offline
Wobble's Avatar
SORE MEMBER
Light grey is normally tach signal, dark grey can be a navigation light
Wobble is offline
Old 07-19-2006 | 10:23 AM
GOODT's Avatar
grey is usually tach signal as stated but usually dont have a quick connect on them
Attached Thumbnails What is the gray wire with the....-l107.jpg   What is the gray wire with the....-l108.jpg   What is the gray wire with the....-l109.jpg
GOODT is offline
Old 07-19-2006 | 10:54 AM
Wobble's Avatar
SORE MEMBER
Maybe they had an MSD box in there at one time.
Wobble is offline
Old 07-19-2006 | 11:02 AM
mats's Avatar
It is the auxilary tach lead.
mats is offline
Old 07-19-2006 | 11:05 AM
I'll due more investigation, but the tach seems to be working fine right now.
29scarab is offline
Old 07-19-2006 | 11:09 AM
mats's Avatar
The auxilary tach lead is spliced together with the regular tach lead. It is for connecting an extra tach.
mats is offline
Old 07-19-2006 | 12:44 PM
thanks mats!
29scarab is offline
Old 07-19-2006 | 10:30 PM
Dave_N's Avatar
hey mats,
Did you get your engine runnng right? I miss your posts.
Dave
Dave_N is offline
