Fuel Tank Vents
Old 07-21-2006 | 10:46 AM
Default Fuel Tank Vents
If I'm not careful I get the "gas puking vent" when I fill up and judging from this OSO search, so do others.
http://www.offshoreonly.com/forums/s...gas+tank+vents
So my next question is why do boats have separate vents from the filler? Cars have the vent tapped into the top of the filler neck so the pump will shut off when it tries to puke. What's wrong with that setup and then use a vented cap like older cars?
Shah Mat is offline
Old 07-21-2006 | 10:54 AM
88formula223's Avatar
NO WAKE ENFORCER
Default Re: Fuel Tank Vents
probly something to do with the size of the tank.... mine does the same thing I know someone told me Formula has a check valve you can put on the vent hose to prevent the Pukeing, last time I filled up mine wayyyy to much and it leaked dripped out for two days....
88formula223 is offline
Old 07-21-2006 | 11:02 AM
dirtlawyer's Avatar
Not sure why the separate vent, but I had a problem with my vents letting in water when it rained - we sealed mine off and then replaced the fuel fills with ones that were an integrated vented unit. They don't look as cool as the old annodized fills, but now I'm not emptying my fuel water separators everytime I go boating after it rains.
dirtlawyer is offline
czy40p's Avatar
Can not help much on the why they are vented the way they are, I just ordered one of these. Should help with spills when filling up.
http://www.iboats.com/mall/index.cgi...&view_id=37945
czy40p is offline
Old 07-21-2006 | 11:08 AM
LostinBoston's Avatar
http://www.boatus.com/Foundation/Fin...s40/vented.htm
deck fills with vents.
There is also a proiduct which i cant find now, but catches the vented fuel.
LostinBoston is offline
Old 07-21-2006 | 11:16 AM
found it
http://www.shipstore.com/SS/HTML/DAV/DAV376.html
Old 07-21-2006 | 01:23 PM
Strip Poker 388's Avatar
Rob
On my Hustler when it pukes it will even start to siphon and start really flowing out
Strip Poker 388 is offline
fruitta55
Banana Boat
10
05-11-2005 08:27 PM
fruitta55
05-08-2005 04:45 PM
JGB
22
09-24-2004 01:44 PM
JGB
Cigarette
0
09-24-2004 09:21 AM
JROMY
2
07-23-2003 07:29 AM
